Volks AutosJMB Retrofits
Results 1 to 17 of 17
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,280
    Foam Lance Help.
    I've been looking at ordering a HD foam lance but i'm not sure what nozzel I need for my Karcher jet wash. I have a Karcher B203 so i'm not even sure if there is a nozzel for that model to use the HD lance. Can anyone advise me if I can?
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Add Jimmeh on Facebook
    Ive just had a quick scan on DetailingWorld and it seems a few people with the B203 have put through orders for a KArcher fitmented lance.
    Might be worth contacting the supplier direct.
    Tim at CleanYourCar is worth a try or wait for our very own Rich to pick this thread up. (polishedbliss)
    Audi A4 Avant 1.9TDi 130 Quattro Sport.
    WhiteDetails.co.uk - Facebook? Follow me!
    Westy's Avatar
    Dec 2008
    17,280
    Many thanks Jim.
    S3 Build Thread
    Westy's Avatar
    Dec 2008
    17,280
    I've been doing a few searches and I can find much about a decent 3rd part foam lance for the Karcher B302. I dont want to fork out on a new jet wash because there's nothing wrong with the B302.
    HAs anyone used a foam lance straight off their hose pipe, and is it as good as one off a pressure washer?
    S3 Build Thread
    Jimmeh's Avatar
    Mar 2006
    East Midlands
    1,426
    Contact Rich @ PB Westle - he might have contacts.
    An alternative is the Gilmour lance.. which, connects to the hose itself IIRC. Never used and never seen in operation so I can't comment.
    Just a thought, it might be worth posting a question on DetailingWorld to see if there is anyone local to you in which you could borrow their connector - or atleast pop round and see if it fits your lance
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Err, can you post a picture of your lance handle/connector please? I've done some digging and have seen images for the B203 showing a standard K-Series bayonet connector? If this is the case, the standard HD Lance with K-Series connector will work perfectly...
    Westy's Avatar
    Dec 2008
    17,280
    Thanks Rich. I cant find a pic of my jetwash on the net but it does seem to have exactly the same bayonet as the K series. I it doesn't fit i'm guessing I can return it???
    S3 Build Thread
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Of course!
    Westy's Avatar
    Dec 2008
    17,280
    Quote Originally Posted by WX51TXR View Post
    Of course!
    Cheers Rich I got my lance today so I'll be trying it out tomorrow morning.
    Can anyone give me some instructions on how to use it? I notice I can twist the nozzel to open or close it and adjust the tap on the top.
    Am I supposed to fill up the bottle full with my Meguires Hyper wash or part meguires part water? Help
    S3 Build Thread
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    Quote Originally Posted by Westle View Post
    I put about an inch of solution in the bottom of the bottle and then top it up with hot water from the tap.
    If find its not making enough foam then either add more solution or look at getting some proper snowfoam. I use PH neutral stuff off cleanyourcar.co.uk and its very good.
    The nozzle adjustment will adjust the 'fan' of the foam when it comes out. I tend to set it so it sprays about a 12" wide fan which works quite well. The knob on the top adjusts the mixture, if you turn it towards the '+' it makes a more solution heavy foam, turn it to '-' and it makes it thinner.
    Foam the car and give it 5 minutes to dwell before washing off. chuck the left over solultion into your bucket when you wash the car after. I normally have a couple of inches left in the bottom of the bottle on the lance after I've given the car a good foaming.
    Just give it a go.....quality fun!.
    T
    2000 Audi A3 1.8T Sport - Custom Code Phase 1 remap / Custom Stainless Catback Exhuast / MKII 18" RS4 Reps / Wietec Ultra GT40mm / KW ARB's / Forge TIP / Forge 007 / Green Panel Filter / EBC Greenstuff pads / 312mm S3 front brake upgrade / Aero Wipers / LED Interior Lights / LED Side Repeaters / Face Lift Rear Lights and covered in Dodo Juice
    Westy's Avatar
    Dec 2008
    17,280
    Cheers Tom, I'm off to wash in a few mins
    S3 Build Thread
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    How did you get on with it then?, manage to cover the whole street in foam like I did the first time I used mine?
    Westy's Avatar
    Dec 2008
    17,280
    haha. Firstly I didn't realise how much of a pain it would be to put the foam lance attachment onto the karcher! I thought it would all be click off and click on attachments but I had to unscrew the karcher to remove the standard bayonet. This is a slight pain as its my dads Karcher so I have to put the standard bayonet back on after i've finished!
    Secondly I did have a slight water leak out of the foam lance where the plastic screw is befor the tap and bottle section. It was only a small jet of water leaking out so I can live with it.
    Thirdly it was great! It was almost like a fire extinguisher, I covered the whole drive and accidently my mums car which was in the garage! I think i'll close the garage door next time.
    cheers for your help again Tom.
    S3 Build Thread
    A3Tom's Avatar
    Smell my finger.
    Mar 2009
    Solihull
    3,509
    They do produce a lot of foam!.
    How did you think it did with shifting the crap before a wash?
    I find that if my cars got a decent coat of wax on it I can almost get away with just foaming it and not doing anything else apart from rinsing it off.
    Generally give it a good foam, leave it for 5 to 10 minutes and then 2 bucket wash though.
    Westy's Avatar
    Dec 2008
    17,280
    Yeah it shifted the lot. Mine hadn't been washed for 2 weeks and it had spent a week in the bodyshop getting the bonnet and bumper done so there were patches of un polished polish on the paint too. I'm very impressed, it made washing a lot easier, and I feel safe that I wont strip the laquer off again with the jetwash!
    S3 Build Thread
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    All good news, nice one. To fix the small leak, undo the connection, wrap around a couple of winds of PTFE tape, then do up again - this will seal it. With regard to the tight fit, was it the foam lance that was difficult to fit, or was it the standard lance that was difficult to remove/refit?
    Westy's Avatar
    Dec 2008
    17,280
    Rich
    it appears that I was being a numpty and didn't realise how to remove/replace karcher attachments! Instead of pushing the bayonet down and twisting it to release it I unscrewed the whole bloddy thing!
    I did think a little touch of tape would stop that leak, I'll sort it this weekend.
    many thanks again.
    S3 Build Thread
