Volks AutosAH Fabrications
Thread: BRAKE!!
    May 2004
    Ca, USA
    51
    BRAKE!!
    check it out guys...i just refilled my break fluid because the light came on. this is the first time it has happened...out of curiosity, anyone experience a problem with breaks/ break lines? i.e. leaking squeeking etc. ? thanks a bunch
    jesters3's Avatar
    The Shire's
    1,516
    Re: BRAKE!!
    Howdy, Got a 2002 S3 and so far she has been fine. No spillage or mess around that area. Maybe have a look at the pipes/lines as they may be split or worn so could be seeping some fluid. Whip off the wheels and have a look, failing that and if it persists maybe get it check in to your local dealer to get them to look further along the pipe/line.
    May 2004
    Ca, USA
    51
    Re: BRAKE!!
    thanx jester
