Chris NottBadger5
Results 1 to 11 of 11
Thread: Snow Foam
    EnzoS4's Avatar
    Sep 2005
    UK
    200
    Snow Foam
    Its time for get some new foam, current use Autobrite which is good, but have no experience of any others... any recommendations...?
    Autobrite - super foam
    Meguiars - hyper wash
    Bilt Hamber - autofoam
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    I'd stick with Autobrite, its great stuff, but make sure you get the PH neutral version as the other version will strip wax
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    axelfols's Avatar
    Jan 2005
    Edinburgh
    124
    Megs Hyperwash is the one i'd recommend. Excellent dilution rate, and kind to bodywork. Incidentally, i've tried Snowfoam and i found it gives me a skin irritation.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by axelfols View Post
    Probably best to stick to the Imperial Leather mate
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    that'll be the non PH neutral stuff which is a caustic TFR type mixture, designed to cut through grease, road film, bugs.....all kinds of grime that build up on the paint, plus snow foam isn't really a shampoo, its a pre-wash that you spray on and then rinse off, if you are coming into contact with it wear rubber gloves
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    I vote for Hyper Wash, for the same reasons given above. We've tried most of the foams out there, but nothing has made us want to make the switch from Hyper Wash.
    Jan 2007
    100
    Where's the cheapest place to get This hyper was from?
    I looked on polishedbliss but couldn't find it for sale
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Our product page for it is here...
    http://www.polishedbliss.co.uk/acata...wash-wash.html
    Most of the popular traders do it, so if price is critical hunt around and be sure to check shipping rates too, as it's not cheap to ship 4kg these days.
    Shez's Avatar
    Sheridan
    Oct 2008
    Brighton
    73
    Hi Rich,
    On a slightly different note does anyone know or have any advice on using snow foam on cabriolets. When washing I try not to get any shampoo on the roof. When snow foaming should I avoid the roof and if I do get any on just rinse out with plain water or should I cover the roof as well, Im guessing the first option.
    Any comments welcome.
    Sheridan
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Hyper Wash won't damage fabric hoods in any way, but continued use of detergent containing products on such materials will remove any surface protectants over time. My advice would be to try to limit foaming of the hood to once a month or so; just often enough to help to keep it clean (wipe it down with a microfibre wash mitt once foamy and then rinse thoroughly), but not every time you wash the car. It's also worth doing a six monthly wash & protect treatment with the 303 Fabric Hood Kit to ensure best long term care.
    EnzoS4's Avatar
    Sep 2005
    UK
    200
    thanks all I also had the same question Shez said about cabriolets...
    so Hyperwash and 303 hood kit... this is an expensive game...
