AH FabricationsSky Insurance
Results 1 to 1 of 1
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Thumbs up New products now in stock!
    We've got lots of exciting new products waiting in the wings at the moment, and this week saw the release of these ones, all of which have been on test for a while in our studio and have proved their worth at the sharp end so to speak!
    Eimann Fabrik Clear Vision II Glass Cleaner - 12.95
    Eimann Fabrik Clear Vision II Glass Cleaner is a highly advanced, non-toxic, environmentally friendly glass cleaner that has been specifically formulated to remove grimy films and provide perfect streak-free clarity. Originally developed for use in hospitals and the food service industry, this product contains no volatile organic compounds, and instead relies on an electro-chemical nano-scrubbing process to suspend grime and oil molecules in an emulsion that can easily be wiped away. Designed for use both inside and out, Eimann Fabrik Clear Vision II Glass Cleaner is completely safe to use on all window tints. For best results, we recommend that this product is used in conjunction with a Microfibre Work Towel.
    Eimann Fabrik Engine Degreaser- 14.95
    Eimann Fabrik Engine Degreaser is a highly advanced, environmentally friendly degreaser that has been specifically formulated to safely and effectively remove tough deposits of grease and oily grime from virtually any type of surface. Despite its outstanding cleaning power, this product contains no volatile organic compounds whatsoever, and instead utilises a state of the art, non-ionic surfactant developed in Sweden. This surfactant is fast acting and safe for use on all painted, plastic, vinyl, rubber, glass and metal surfaces, both inside and out. For best results, we recommend that Eimann Fabrik Engine Degreaser is applied liberally and agitated with a Meguiars Slide Lock Detail Brush before being rinsed off.
    Deep Pile Luxury Drying Towel - 9.95
    This double thickness microfibre drying towel features an incredibly deep pile, and is capable of absorbing many times its own weight in water, making it ideal for drying off after washing and mopping up excess lubricant when using a clay bar. The generous size of this towel means that you can dry most cars without wringing out once and the ultra-soft fibres significantly reduce the risk of adding fine scratches when drying off or mopping up. Another great feature of this towel is its seamless, tag-free design, which further reduces the risk of marking the paint. If you hate pat drying, then this towel is the towel for you!
    Deep Pile Luxury Buffing Towel - 3.95
    This double thickness microfibre buffing towel features an incredibly deep ultra-soft pile with a high degree of absorbency, which makes it ideal for buffing off last step product residues and gently wiping down bodywork when quick detailing. Another great feature of this towel is its seamless, tag-free design, which greatly reduces the risk of marking the paint.
    Raceglaze Signature Series Pre-Wax Cleanser -14.00
    Raceglaze Signature Series Pre-Wax Cleanser is a brand new product from Raceglaze designed to prepare painted surfaces properly ahead of applying wax protection. It is highly recommended for use with Raceglaze Signature Series '42' and Raceglaze Signature Series '55', but is also entirely suitable for use with other paste waxes. Designed to be quick and easy to both apply and buff off in all weather conditions, including bright sunlight, it gently removes old wax residues and lays down glazing oils to help hide fine swirl marks and enrich the colour and glossiness of the finish. Raceglaze Signature Series Pre-Wax Cleanser can be easily applied by hand or by dual action machine with relatively little effort and with equally good results.
    Cut: 0/10 Gloss: 9/10
    Raceglaze Colour Enhance Trim Dressing - 7.95
    Raceglaze Colour Enhance Trim Dressing has a mild solvent-based cleansing action and is ideal for reviving neglected interior surfaces and restoring badly weathered exterior trims and seals. It can be used to safely clean and dress all plastic, vinyl and rubber surfaces inside and out but, unlike many rival products, it will not leave behind greasy or oily residues. Instead, all surfaces will be left dry to the touch with a highly durable natural looking sheen.
