Badger5Sky Insurance
Results 1 to 9 of 9
    Soon be christmas!!!!!!!!!!
    Feb 2008
    North Wales
    163
    advice after major detail!!
    Just bought lots of goodies from the lovely people at Polished Bliss, Menzerna Intensive Polish, Menzerna Finishing Touch Glaze and Blackfire Midnight Sun Ivory Carnauba Paste!!!!
    I have only done the bonnet so far, just to see how it goes and due to the lousy weather!! I've got two questions really, what's the best way to apply the wax? I used a Lake Country CCS Applicator Pad to apply a light coat then buffed off with a micro fibre cloth, do i need to work the wax a lot or is it just a case of "wax on wax off"???!!!
    The other question i have is what's going to be required to keep it looking nice after a wash? Just keep adding wax?????
    Any advice is greatly appreciated
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    A good place to start is to read the sticky threads at the start of the detailing section. Lots of really good advice there. Other good advice over at www.detailingworld.com
    james b's Avatar
    Jul 2007
    85
    i would recommend having a look at detailingworld.co.uk all you will ever need to know about cleaning your car is on there if you take the time to look around
    contact admin to advertise
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    I'm no expert, but I'm confident there's no way you'd have to re-apply the wax every time you wash.
    You're paying for finish and endurance, after all.
    I currently use Meguires Crystal polish to get the car shiny, maybe two or three times a year.
    On top of the polish, to keep it shiny, I use Collinite Marque D'Elegance wax, maybe three or four times a year.
    In between that, a quick wash (with a wool glove) and dry (with microfibres) has it looking top notch again.
    I will be switching to polishedbliss products (Blackfire Midnight Sun) when my existing products run out, but I don't expect any more effort.
    I still expect a good polish no more than two or three times a year, with three or four applications of wax per year to keep it looking good.
    With regard to application of wax, I use Meguires foam applicator pads, then immediately buff it off.
    I do this panel by panel.
    This matches their (Collinite) instructions and works well.
    I used to wax the whole car, then buff it off.
    The wax used to go rock hard though, making the buffing a nightmare!
    To me, good quality products are as much about making your life easier, as looking good.
    When the wife moans about wax costing xx per tin, I point out the fact her car always looks good and I don't have to spend much time doing it.
    '02 to '05 - Black Audi A4 1.9tdi sport
    '05 to '08 - Akoya Silver A3 sportback S-line DSG
    '08 to ? - Black Alpina D3
    Nov 2006
    Cheshire
    881
    no need to keep adding wax after a wash. i find a good way to keep your car looking fresh is to wash, then while the car is still wet spray quick detailer onto the car and dry as normal.
    Audi A3 2.0TDI S-Line
    OEM+
    Coming soon: VW Passat 2.0TDI 170 DSG
    Feb 2008
    North Wales
    163
    cheers for all the replys troops!!! Spot on :-)
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Quote Originally Posted by btmotorsport View Post
    When applying the wax, there is no need to work it in, just spread a lovely thin layer over the panel, then leave a few minutes and buff off gently using a plush microfibre towel. No effort should be involved!
    For routine maintenance, washing and drying will be perfectly fine, and will leave the finish looking great. I would suggest that rewaxing every 8 weeks or so would be sensible, as it will allow layers to build up, and increase the overall level of glossiness. If you fell you would like to add a little extra every time you wash and dry the car, you could use a quick detailer when drying off, as suggested above. In this respect Blackfire Deep Gloss Spray Sealant is an ideal choice, but it is in no way essential to ensuring the finish looks good; washing a periodic rewaxing alone will see to that.
    Amchlolor's Avatar
    Jan 2005
    Aberdeen
    5,602
    Rich, what would you recommend for my metallic black BMW?
    I was thinking of that Jeff's acrylic kit thing + blackfire midnight sun?
    Or is both OTT?
    I must get my arse out to Kintore soon....
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    The Werkstat Acrylic will give you a lovely sharp shine with plenty of flake pop, but no real sense of gloss. Adding the Midnight Sun would give back the missing gloss, but would then mean topping up would have to be limited to fresh wax layers... which take more time to apply/buff than fresh coats of the Trigger. My advice would be to start with multiple layers of the Werkstat and then evaluate the finish - if you like it, then leave it at that and save your cash. However, if you find you end up craving more gloss, then you know the Blackfire is the way to go.
