Other top tip - always wash your car yourself - mines not gone near any cheap hand car washes or jet/drive through washes as the brushes just put fine scratches all over the car.
Long answer... but hope it helps.!
Hey Juniper,
I got in touch with Rich at Polished Bliss before receiving the car - it was my frist car from brand new and I wanted to make sure I looked after it properly. Rich recommended the Werkstat Acrylic kit (amongst many, many other questions!)
The car was delivered in a lorry to me and was immaculate when it arrived.
Before I even took the car out for a spin I set about adding the Werkstat Acrylic kit, Prime first, then a couple of layers of Jett.
Every wash after that I added another layer up until I got to about 5 or 6 layers.
Then added another couple of layers of just the Jett every couple of months.
The car stayed looking in great condition, but then had this issue to contend with:
http://www.audi-sport.net/vb/showthread.php?t=55348
Since getting the car back after this I have given the car it's first clay, that was after about 14 months of ownership and a long drive to the alps and back. Keeping on top of the Werkstat applications means it's harder for the contaminants to bond to your paint and you therefore need to clay less.
When I do clay I use meguirs mild clay - I don't trust myself with anything harsher.
Khalil,
As per the PB guide the Prime should be used first (after optional claying) This cleans up the body work and leaves an initial base of acrylic to begin with, residue of this prime is occasionally a bit tough to remove (I have not found it hard) so the glos is used to cut the prime and should be wiped off before moving onto the trigger stage.
The trigger is applied last and as someone else will probably confirm is a glaze or sealant step as opposed to a wax. The trigger can sometimes be hard to fully buff off and as before can be cut by the glos. I hope this helps!
I use this system and whenever I have long enough to do my cars I like to apply the trigger and buff off to such an amazing shine and a car that is so slick and easy to wash the next time.
Sounds like you have been through the mill with yours.
Thanks for the advice though, since i have had mine have been very careful with regards to washing (the polished guides helped immensely) I will always wash it myself and the longest it has gone without a wash is about 4 weeks.
Got some good products also from polished bliss, it had a great coat of wax on it from new and was in tip top condition so didn't want to overload with wax.
I'm tempted to clay in a couple of months time then apply the acrylic kit so the wax is going onto a perfectly clean surface.
Thanks for the help.
BTW - you still loving the car? I'm loving it (especially when people look at the car and see a woman driving it)
