WX51TXR
Polished Bliss
- Joined
- Mar 6, 2005
- Messages
- 1,452
- Reaction score
- 16
- Points
- 36
- Location
- AB51 0TH
- Website
- www.polishedbliss.co.uk
With our six month waiting list causing the odd bit of grief with both new and existing customers, and Marsha now happily in post and tackling the orders, I guessed it was about time I should ease myself out of my chair and dust the cobwebs off my Makita... roll on a summer full of weekend details.
First up, a nice RS4, recently modified with a nice set of arch filling 20s of off an S5...
I'd inspected the car a month or two back and booked it in for a minor correction detail, as in the sun it didn't look to bad at all. Big mistake, but I'll come back to that later. First of all, the wash process, starting with setting up the waste water collection bund...
Hot foam at 60oC does a marvellous job of removing traffic films and the like, but bug splattered front ends and dirty trims always benefit from a pre-soak with P21S Total Auto Wash...
as do door shuts...
and engine bays...
After a little light agitation with microfibre wash mitts and several brushes. I rinsed the whole lot off at 60oC, and then switched the lance into hot foam mode...
With the foam soaking, I set about the wheels, finding that only normal suds were required to bring them up 100%...
After rinsing off again at 60oC, I then used Autosmart Tardis to remove any remaining bug splatter and tar spots. This product is best applied neat, and should then be left to work for a minute or so before being wiped gently with a microfibre work towel - this ensures any stubborn residues are removed. A top tip is to bin the towel after use, as if you try and wash it it will stink out your machine...
After another thorough rinse off, I rolled the car inside and clayed the glass and bodywork using Meguiars detailing Clay Mild and Last Touch as the lube...
Then it was back outside for a final rinse before drying off with the leaf blower. Just at this point the sun made an appearance, and this is what I could see - pretty much the same as when I had first inspected the car. Menzerna 106FA and a polishing pad it was to be then - hurrah!
However, this turned out to be a hasty assumption. Inside, under the 500W halogens numerous other defects started to appear... including some nasty random scratches on virtually every panel. Hmm, maybe 106FA won't cut it after all...
Bonnet Before
Bonnet After
The final process needed here was 1 x 106FA @ 1800rpm on a 3M High Gloss Polishing Pad, 2 x RD3.02 @ 1800rpm on a 3M High Gloss Polishing Pad, and finally 1 x 85RD on a 3M Ultrafina SE Finishing Pad. Fantastic... the dream of an easy single stage process was well and truly out of the window. Here's me finishing off the bonnet...
The roof required just 1 x RD3.02 @ 2000rpm on a 3M High Gloss Polishing Pad, and finally 1 x 85RD on a 3M Ultrafina SE Finishing Pad. But then the bootlid reared its ugly head, and when I saw this...
...out came the big guns. 1 x 3M Fast Cut Plus @ 1800rpm on a 3M High Gloss Polishing Pad and then 1 x 85RD on a 3M Ultrafina SE Finishing Pad gave me this...
Why not use a compounding pad? Well, some of the curves on the RS4 are a pig with harder pads, and Fast Cut Plus seems to work very well even with a soft pad, so why make life harder? This panel set the process for much of the rest of the car... but by this point it was 7pm, so time to call it a day with just the bonnet, roof and bootlid fully corrected.
Total work time for day one = 11 hours.
as do door shuts...
and engine bays...
Bonnet Before
Bonnet After
