AH FabricationsVolks Autos
    Apr 2008
    171
    Recommended polish to use after wet sanding?
    Hi Guys.
    I have just wet sanded out the orange peel effect and i am wondering what is the best polish to use with my polisher?
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    What grit of paper did you use Sherry?
    Apr 2008
    171
    hi jr001
    i used 2000 grit.
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    Menzerna Intensive Polish 3.02 on a polishing pad should be fine. It's designed for removal 0f 1500-2500 grit sanding marks. Medium pressure during removal of marks followed by a few passes on lighter pressure to gloss the finish nicely. It's effectively a 2-stage polish if worked for long enough. Hope this helps.
    Apr 2008
    171
    It sure does help jr001.
    Thank you so much m8.
