Gave my S3 its first proper clean and tidy up the last couple of days, was a bit neglected when I got it...
Process....
Foamed using Megs Hyperwash in the Autobrite foam lance, does a good job of loosening the much off the car.
Then washed using the two bucket method with two Megs wash mits and Poorboys supersuds solution...dried off using Poorboys waffle weave towel.
Car was then clayed using Megs Quick Detailing Clay, first time i've used a clay and it was much easier than I thought it would be, noticable difference as well.
I then got out the Jeffs Werkstatt Carnauba Kit that I got from polished bliss. Car was covered in the Prime and then buffed off 30 minutes later (this was hard work ! )
I then covered the car in the Carnauba Jett and buffed off using the Gloss when needed...
The next day I tackled my seats ! They where very shiny and full of grime so I went with most recommendations and ordered the Gliptone cleaner and conditioner, the difference is unbelievable, seats are now clean, soft and matt ! They look like different seats, well worth the £10 it cost !
Here are the pictures...
Process....
