Badger5EM Tuning
    Apr 2008
    171
    how to remove orangepeel effect
    Hi guys.
    Can anyone recommend how to get rid of the orange peel effect. I got it sprayed at a night class at college and would love to get the peel effect removed.
    Cheers.
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    It's probably going to be best solved with wet-sanding, followed by machining out the sanding marks.
    That's assuming the orange peel is in the clearcoat and not the paint. If it's in the paint then I'm afraid it's a much bigger job than just sanding!
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    As John says, it always requires a lot of wetsanding (best by machine using a paint thickness gauge to monitor the removal rate) and then some aggressive machine polishing to remove the sanding haze. See here for a good example of how it is done...
    http://www.detailingworld.co.uk/foru...ad.php?t=60680
