    axelfols's Avatar
    Jan 2005
    Edinburgh
    124
    Foam Lance mixture
    When dilluting foam mixture for lance. Is it best to use hot water for the mix? My pressure washer does not spray warm water and i was thinking this may help with the cleaning procedure.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Yes, absolutely. It doesn't warm the foam as such, but is does activate the foaming agents better, meaning thicker foam, and more of it. I use really hot water to top up my bottle before fitting them to the pressure washer.
