Volks AutosJMB Retrofits
    Kontraband's Avatar
    Dec 2007
    1,998
    Pressure Washer deal
    Whilst I look at trying to get a pressure washer for my shiny new motor, I came across this karcher big boy...
    looked pretty good and I could use if on the patio...
    I really have no idea tho on pressure washers and have had a look at some of the posts on here and people dont seem to have had much luck with karcher, or maybe the lower end of the karcher range?
    Any comments?
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    I've used Karchers (low end and high end) for the last six years, and never had any real issues with them; only one needed a pump replaced, and that was after several years of extended use. My old K399 served me well at home, and was ample enough for car cleaning duties. The new equivalent is this one...
    http://www.cleanstore.co.uk/products...ct.asp?ID=4154
    Maybe the one you have chosen is a bit overspecced? That said, bigger can be better, but unless you are getting hot water at pressure then the little domestic ones will perform just as well as the big boy domestic ones when it comes to cleaning your car.
    Kontraband's Avatar
    Dec 2007
    1,998
    cheers Rich.... over specced no doubt... its a weakness.
    picked up one like the robert dyas link for 150 in B&Q this easter weekend...
    Used it this weekend... all good. Though I think I need some cleaner for it.
    AudiLad's Avatar
    Feb 2008
    Liverpool
    145
    ares is like 4-5 years old an it works brilliant
    Lava grey pearl (A3 2.0 TDI sport 140) 2004
    Kontraband's Avatar
    Dec 2007
    1,998
    nice! Hope mine will be the same...
