Volks AutosJMB Retrofits
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    karcher foam lance & Chemical Guys Maxi Suds. Water ratio advice?
    Hi,
    Just bought these products for doing pre-wash. I was recommended the Meguiars Shampoo Plus, but just couldn't find anywhere that has any in stock at the moment. So got the Maxi Suds, hopefully, as a good alternative.
    I just need some advice on what ratio of Shampoo to Water I should use.
    Also, for info, my car has Zymol Royale on, will Maxi Suds be ok and not strip the wax?
    AL
    '07 Phantom Black S3 - '07 to now - Bucket Seats, FBMFSW, BOSE, Symphony II+, Cruise Control, Elec Folding Mirrors, Front Centre Armrest, Rear Armrest & Through Load, Interior Light Pack, Luggage Pack, Reversible Boot Mat, Luggage net.
    '02 Silver S3 (225bhp) - '02 to '07
    '99 A3 1.8T - '99 to '02
    '11 Rising Blue Golf R - '12 to now - 19" Black Talladega's
    '52 Black Golf GTi MkIV Anniversary - '03 to '12
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    Quote Originally Posted by AL_B
    Hi,
    AL
    the maxi suds won't strip the Royale as it is ph neutral but its a bit expensive to be using as a pre-wash thorugh a foam gun.
    you shouldn't really need to add any water to the chemical bottle on the foam lance attachment as the chemical is mixed with water as it sprayed through the pressure washer.
    you can get meguiars gold class shampoo from halfrauds for about 14 for 2 litres
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    Oct 2007
    South Africa / London
    41
    There's a fantastic write up here:
    http://www.meguiars.co.uk/phpBB2/viewtopic.php?t=2417
    Should be a good base point for determinig the right mix ratio
    A4 TDI at the moment...Alpina XD3 on order!!!
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Around 4:1 (water:shampoo) in the foam gun bottle should be about right, assuming a standard mix ratio of 128:1. However, sometimes a little playing around is needed. A much better bet in the long run through would be Meguiars Hyper Wash, as it is designed for foam usage and has a daft mix ratio of 400:1, meaning you only need to use a tony amount in the bottle to generate very thick foam. It is also safe for use on high end Zymol finishes; we maintain Vintage finishes with it with no problems at all.
