Chris NottMonster Motorsport
Results 1 to 23 of 23
Thread: T-Cut
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,839
    Question T-Cut
    Silly question really, but what's the take on T-cutting paint from the professional detailer's point of view?
    You've got to have a laugh!
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    it's crap! you won't remove any swirls/scratches and will most likely put more in. you might remove oxidisation and give a bit of life to the paint but thats about it
    what result/work are trying to acheive/do?
    A4 2.5 TDi quattro sport saloon
    RNS-E DVD Nav running SW 0600 with 2007 disc including TMC function, Bluetooth Telephone, Audi iPod Interface
    18" RS6's now gone, replaced by OEM 18" S4 alloys
    Retrofit S-Line Bodykit
    Retrofit OEM Xenon's
    Retrofit Front Ambient Lighting
    Retrofit OEM Aero Wipers (thanks PJMSpeedy)
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,839
    Quote Originally Posted by 1210tech
    I was just asking out of curiosity.
    stan's Avatar
    Dec 2006
    Devon
    136
    I've had great success with t cut but only on CDs that are scratched, repaired manys CDs DVDs with this stuff.
    S-Line
    Obsessive Car Detailer
    Manchester
    47
    Quote Originally Posted by jojo
    I am a pro detailer ...
    T-cut doesnt contain diminishing abrasive therefore will put in just as much scratching as you try to remove with it... it also contains ammonia and can discolour single stage paint ...
    T-cut got left behind in the 70's... there are MUCH better alternatives these days to use.
    Wanted: 2000/2001 Audi A3 1.8T Sport...
    Will PX against this: http://www.pistonheads.com/sales/330954.htm
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    As above... in many cases it seems to do more harm than good for the reasons offered above... and there are now many more polishes out there that do a significantly better job, whether by hand or machine. My advice is leave it on the shelf and instead use a set of modern polishes with finely milled diminishing abrasives that are suited to hard germanic paints; the Menzerna range is probably the best currently available in these respects.
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    any recommendation then from the pros?
    1210tech's Avatar
    Four Ring Fanatic
    Nov 2006
    Birmingham, UK
    689
    Quote Originally Posted by abdus
    as rich said above, the menzerna range, either PO106FA or probably PO85RD3.02 are gonna be your best bet on vag paint but by hand its gonna be a complete ***** and take you days rather than hours. your gonna need to use, at the very least, a random orbital polisher such as a porter cable with a medium to hard polishing pad to remove any paint defects.
    go here and have a browse: http://www.detailingworld.co.uk/
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    If you choose to work by hand, you've little chance or removing anything more serious than minor marring, so often the best bet is to use a glaze like Menzerna Finishing Touch Glaze or Blackfire Gloss Enhancing Polish to fill and hide any defects, and then seal the finish with a decent wax or sealant (to boost the gloss and lock in the fillers). However, if you really want to attempt some degree of correction by hand, and have arms like Popeye, then Menzerna Intensive Polish applied using the white side of a German Pad will yield some improvement, and will break down properly to leave a decent finish (even if defects still persist). However, if you are happy to consider buying a machine polisher, then you will be able to make much more headway in terms of correction...
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    Thanks...so best bet would be a polisher then...
    any good polisher below £50?
    lol..can't afford more than that atm due to baby on the way in 5 weeks...
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    any good polisher below 50?
    With all the things you 'have to have' for a new baby these days you will have some electrical gadget that will be useful for applying polishes.
    Couldn't you adapt one of these?
    Good luck with with your new arrival when he or she arrives.
    I'm an optimist but I don't think it helps much.
    A3 8P 2.0TDi S-Line Sportback DSG
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    LOL...thanks. It's a baby girl. Can't wait anymore for her to come now
    on a more serious not, I was thinking of getting a silverline off ebay
    http://cgi.ebay.co.uk/PROFESSIONAL-Q...QQcmdZViewItem
    or this:
    http://cgi.ebay.co.uk/TRADE-POLISHER...QQcmdZViewItem
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    The problem with the two you have listed is that they are not random orbital and , unless you know what you are doing, you could easily burn the paint on your car because of heat build up. The random orbital versions are much easier for a novice to use and, unless you are particularly careless, almost impossible to do any damage.
    I'm not sure either of those would be a great purchase unless you are well practiced and know what you're doing.
    Clark@Polishedbliss's Avatar
    Professional Detailer
    Feb 2007
    Aberdeen
    228
    Quote Originally Posted by marms
    Wise words
    If money is an issue regarding purchasing a machine polisher, maybe keep an eye on Ebay for a 2nd hand PC (Porter Cable) but even then it wont be as cheap as 50 i'm afraid. Maybe just save a bit untill you can afford one or a new Meguiars G220, at least by then the warmer and dryer weather will be here
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    so a UDM model 1000 would be good enough for a start?
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    OK, I bought one of these:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=190190531021
    no worries about burning the paint etc...
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Don't forget you will also need the 110v convertor and a plug to make it usable in the uk. Apart from that I think you've made a good choice. Blow the 50 budget a bit though
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    yeah, looking for 2nd-hand transformer from a friend. Just need to buy the plug.
    Better invest in something worthwhile and save a respray job with a crap polisher...lol
    Just above budget
    marms's Avatar
    Jan 2007
    Lincolnshire
    837
    Abdus,
    I replied to your PM so I think you have everything covered now.
    Good luck and don't forget to post the picturess of your efforts when the car has had a once over
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    Cheers Mike...will post when used and satisfied with the results.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Full guide on how to polish hard germanic paints safely by hand or machine now posted here...
    How to safely and effectively polish hard paints by hand and machine
    abdus's Avatar
    Top Gear
    Cell-Out Champion
    Apr 2007
    On an Island
    1,809
    Quote Originally Posted by WX51TXR
    nice one
