Chris NottBadger5
    Nov 2007
    11
    Burnt on brake dust
    i have quite a few burnt on brake dust spots on my alloys. I use the menzerna gel for cleaning them but it just wont shift the spots. If i clayed them will that shift them?
    Sep 2007
    North-East UK
    96
    Claying them should be fine and will most likely remove the contamination. There's a PB guide on cleaning and protecting wheels:
    http://www.polishedbliss.co.uk/acata...es_wheels.html
    MY2011 A1 TDI Sport
    Amalfi White, Sat Nav, Bose, Xenon Plus, Climate Control, Competition Line Trim, LED Interior Lights, Light & Rain Sensors, Polygon 18" Wheels. Retrofit Armrest, Cruise Control & Gauge Sweep. VCDS.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Just to add to the above, if you have some sturbborn spots clay may work, as might a stronger acid based cleaner, but also consider that they may be tar or rubber spots; wheel cleaners won't budge these, but a decent tar & glue remover will. We frequently use strong cleaners and then tar & glue remover to fully clean bad wheels coming in to us.
