Volks AutosAH Fabrications
Results 1 to 7 of 7
Thread: Engine cleaning
    jesters3's Avatar
    The Shire's
    1,516
    Engine cleaning
    Hello,
    Looking to give the engine a good going over this weekend. Will be getting some degreaser to do the job. One question I had is will the degreaser work on the 'metallic' metal parts (not the alloy caps) like the throttle body?
    Hopefully this picture will help
    Jester
    "On my second S3 and loving it. RS3 here I come!!!"
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    I use Gunk.
    I buy the big tin of stuff and a plant sprayer thing...spray the Gunk on, work it in with a paintbrush, leave it 10 mins or so, then hose off.
    Works a treat.
    Sometimes it takes a couple of goes, but it takes metal back to perfectly clean and de-greased.
    It smells a bit though, so wear gloves, 'cos once it's on your skin, it takes ages to come off!
    Please note:
    The views expressed on Audi-Sport.net are the personal views of its contributors (including me), and not that of the Website or the Moderator/Administration team.
    jesters3's Avatar
    The Shire's
    1,516
    Thanks I'll give that a whirl.
    Jester
    Hotscar's Avatar
    Four Wheel Drifting
    Sep 2005
    West London
    543
    Have a look at this thread and here are some more pictures. I never did anything other than dilute the degreaser, poor it on and rinse bearing in mind my car's done 60k. I'm sure if you were to use a few rags and elbow grease the results could be even better.
    Meguiars Super Degreaser
    Unmolested Ming blue S3 (so it doesn't handle or stop very well), Bose, sunroof and centre armrest but no heated seats - Gone but not forgotten although I am enjoying the new 350CLK!
    PSN - S3hawkster
    MikeA3's Avatar
    Mar 2005
    Epsom
    1,176
    might be a daft question but what do you use to cover the electrics? - cling film or something similar?
    S3 AMK
    Bilstein B8's & Eibach Springs, Neuspeed ARB's (22mm front & 19mm rear).
    Badger 5's Machined Discs with DS2500 pads & HEL braided lines.
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    Kithen Foil is quite good since it moulds well around the parts. And no, there is no danger here of short circuiting as long as you have your ignition switched off!
    Make sure any air intakes are covered too.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    More general info on engine cleaning here...
    http://www.polishedbliss.co.uk/acata...es_engine.html
