AH FabricationsEM Tuning
Results 1 to 23 of 23
    marriedblonde's Avatar
    Dec 2004
    Sunny South Coast
    4,368
    snow foam and jet washer
    Hiya
    I've bought myself a snow foam gun but the connection on it is for a hose pipe and not for a jet wash. Where can I get a hose that will connect to the jet wash and has the quick release hose adaptor on the end?
    J.
    Married and blonde yes, but still a guy with a poor taste in usernames!
    Mercedes Benze E-class 350 sport convertable, black, pacha grey leather, 19" AMG rims, HK stero and a few more toys
    VW Scirocco 2.0Tsi GT with Revo stage 2, evoms induction kit, lowered, short shift, miltek
    BMW 330 Coupe M sport Black, Black leather, Nav and a lot of other options.
    BMW Z4 Coupe Sport in black with a few toys - going friday and gonna be missed by my lad.
    A3 2.0Tdi S-Line DSG. Gone but not forgotten
    Dec 2004
    Sunny South Coast
    4,368
    oh it's the gilmour foam master 2 I've bought!
    Not sure if there is a choice out there!
    J.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Err, if you have the Foamaster II, it's only designed to be used on the end of a hoselock hose, not to be attached to a jet washer? I do know of one or two folk that have tried attaching their Gilmour's to jet washers, but it does not work that well; better to use it on the end of the hose in my opinion! If you want to source a connecting hose though, best bet is to go to B&Q and buy a short length of hose, plus the quick release connectors (they'll be in small packets alongside the hoses - then go home, cut the hose down to the desired length, and fit the connectors (they just push on to the hose ends and then screw tight). Hope that helps!
    Dec 2004
    Sunny South Coast
    4,368
    Ah ok fair enough, I thought it needed more pressure to generate the foam. Attached to a hose it doesn't produce the foam like Ihave seen in the pictures on here!
    J
    OutLore's Avatar
    VOIP Dude
    Oct 2003
    Essex, UK
    1,183
    Quote Originally Posted by marriedblonde
    J
    What's your water pressure like? IIRC those things need a fair amount of pressure to really work.
    Also make sure you dont have any of the "stop" connectors (the ones with red fittings) as I understand that they can lower the flow rate by as much as 30%!!!
    What product and solution are you using in the gun?
    Spence
    ________________________________________
    Now: 2011 A4 Avant 2.0TDi Black Edition Multitronic Aruba Blue
    Gone at 77k: 2008 A4 Saloon 2.0TDi 140 S-Line Quartz Grey
    Gone at 80k: 2007 A3 Sportback 2.0T S-Line S-Tronic Mauritius Blue
    (4 S-Tronic boxes, 3 Mechatronics Units, 2 Dual Mass flywheels, 2 sets of engine mounts)
    Gone at 32k: 2005 A3 Sportback 2.0TDi 140 S-Line DSG
    Ebony Black
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    J
    If you don't have a pressure washer, a Gilmour Foamaster Foam Gun will fit a standard garden hose and deliver good bubbly foam (providing your water pressure is reasonably good). Use it with Meguiars Hyper Wash for best results. See here...
    http://www.polishedbliss.co.uk/acatalog/pb119wash.html
    http://www.polishedbliss.co.uk/acatalog/pb243wash.html
    Here is an example of the Gilmour in action...
    However, as you say, to get really thick, clinging foam you need a dedicated lance that fits onto a pressure washer; these lances produce loads of ultra thick clinging foam, and can be used effectively with Hyper Wash and all other degreasers, all purpose cleaners and shampoos. Here is an example of the Auto-Brite lance for Karcher fitments in action...
    Dec 2004
    Sunny South Coast
    4,368
    Thanks for replying, looks like I may have bought the wrong one...
    terrymcg's Avatar
    Nov 2006
    West Lothian
    236
    Rich,
    How much product do you put in your bottle to make thick foam like that? Do you top the bottle up with water?
    I have been using sno foam and hyperwash but it is never that thick!?
    57 Plate Imola Yellow S3
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    2-3 pumps of Hyper Wash in a 1 L bottle, topped up to the brim with hot water, with the foam gun set to max, produces foam like that. What lance have you got?
    terrymcg's Avatar
    Nov 2006
    West Lothian
    236
    Its one of the AutoBrite foam lances with the red dial on the side!
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    As above then, our method should work spot on in yours.
    Gti Jazz Blue's Avatar
    Feb 2007
    Hampshire
    1,654
    Well I've invested in the AutoBrite lance and I have 5 litres of their Snow Foam and I can't get it as thick and sticky as you've got it in the pics.
    Still does a good pre-wash job but I'd like to get it as thick as you have it.
    When you say Foamgun set to max, is that with the screw all the way in or out ?
    Thanks.
    Paul
    Gone not forgotten -
    92 Golf Gti Mark 2 16V.
    VCDS HEX-USB+CAN
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    On ours, with the screw all the way in. Snow foam varies in quality too, so try making up a stronger mix in the bottle (and using hot water, which helps to activate the foam). If it still plays up, try switching to Meguiars Hyper Wash next time you need to buy foam.
    Feb 2007
    Hampshire
    1,654
    Thanks Mate,
    I will try that this weekend if/when I wash the cars (weather depending).
    Did the A3 in the rain last weekend (was forcast to be cloudy but not raining on the Saturday). Boy did I get cold Brrrr.
    Paul
    VCDS HEX-USB+CAN
    tris88's Avatar
    Jul 2007
    Surrey
    65
    Where would I buy an Autobrite lance? Also are they compatible with all Karcher pressure washers?
    Audi A3 54 reg 2.0TDI Sport in Mauritius Blue!
    richjohnhughes's Avatar
    Oct 2007
    104
    tris88's Avatar
    Jul 2007
    Surrey
    65
    Thanks will add that to my xmas list lol
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Quote Originally Posted by tris88
    All domestic units yes; a different fitting applies to the bigger commercial HD series units. Just note that in a minority of cases the lances can be a very tight fit onto the Karcher gun; sometimes to the point where you have to drill out the brass barrel on the new lance a wee bit. This is dead easy and no big deal, but just worth knowing before you buy.
    tris88's Avatar
    Jul 2007
    Surrey
    65
    Ahh okay, cheers. Will probably buy a pressure washer and lance soon as I will prob go halves with my bro (helps having someone else around who likes to take care of their car )
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    925
    Just received my new autobrite lance and megs hyper wash,i was amazed how well it works,thick foam straight away and so easy to wash car now.Only one downside,getting rid of all that sticky foam off the drive ,pavement and road.lol.Thanks for your advise,cheers Andy
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO MAP ,STATIS CATBACK EXHAUST,PANEL FILTER.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Aye, it can be quite funny trying to clean up!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    24,845
    Quote Originally Posted by ANDYTQ
    Bugger, I was about to invest in one of these until you posted this up Andy, how bads the foam? My drive is angles towards the house and has a small drain right in front of the garage, and my garage floods with water in heavy rain, so does all the foam disappear with watering down from a hose?
    You've got to have a laugh!
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    It's not really a big problem!
