EM TuningSky Insurance
    May 2007
    65
    Prob been asked before cleaning cloth seats.
    Need to get rid of marks/stains on cloth interior dark blue, what is the best way to do this steam or another product? Could someone recommend a process or product whereby I can remove or at least reduce the marks/stains, some are quite noticeable. I must add. I then intend on putting seat covers on after obtaining the best results I can.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Apply Meguiars All Purpose Cleaner diluted 4:1 with a foaming spray head, then work into the stains gently using either a microfibre work towel or all purpose interior brush. Then soak up as much moisture as possible using a clean work towel. Repeat if needs be, but try to avoid overwetting the fabric unless you have an extractor to hand. If you do have an extractor and the stains are really bad, then shampooing from the off with something like Autosmart's Brisk would be a better idea, using the same method as above but without the fear of overwetting.
