Volks AutosChris Nott
Results 1 to 29 of 29
    Clark@Polishedbliss's Avatar
    Professional Detailer
    Feb 2007
    Aberdeen
    228
    Polished Bliss: Worst Car Yet? (Evo V)
    Well this was a testing detail to say the least, and i'll say now, the pictures do not do this car justice - both with the before's and afters!
    The Car - A Mitsubishi Evo V:
    The owner had come in past last month for us to view the car with a view to detailing it so i knew what was in store for me when it arrived this week, i didnt remember it being quite so bad though, more on this in a bit The Customer had just recently bought the car, and the previous owner had let the car sit for a long time under trees on his driveway as he couldnt afford to get the car through its various tests to make it road legal in the UK - this resulted in the paint looking tired and felt very rough, with signs of oxidization on the roof and bonnet. The paint was also stained in places with what looked like streaky shampoo but it refused to
    shift during the wash/clay stage.
    Firstly the car was foamed with a mixture of P21S Autowash and Megs Safe Degreaser in the AB Lance:
    The arches/shuts/petrol cap etc were all de-greased and the car was then foamed again, rinsed at high pressure then washed with the 2 bucket method and Megs Shampoo Plus. The lower halfs were then soaked with Autosmarts Tar & Glue remover and wiped off with a Mf. The entire car was clayed with Megs Aggressive Detailing Clay, this took over an hour and a half as the paintwork was incredibly rough - as was the glass.
    The wheels were cleaned with Menzerna's 7.5 Tyre and Wheel Gel:
    I then sprayed the wheels with the Tar and Glue remover and made sure i got every last bit of tar removed from the inner rims also:
    I then foamed the car with hyper wash, rinsed off and then dried it with the leaf blower.
    The wash/clay process took nearly 3 1/2 hours in total.
    Here you can see the oxidization on the roof now that it was clean:
    Once inside this was when it hit me just how big a job it was going to be, no need for halogen shots to show the defects.....
    On closer inspection, it wasnt oxidization at all, but actually a mass of bird crap etchings! :doublesho
    Here's a few halogen shots anyways!
    Luckily, the car showed a healthy 130 microns of paint on average and it was incredibly consistant. Only once did i get a reading below 100, the rest were all in between 115-135, including the plastics
    Weapon of choice was Menz IP3.02 and a Megs Polishing pad - and this was where the trouble began, on my first set of passes the polish dried up instantly and welded itself to the paint, but not in the usual way to how it reacts when it "plays up". I then tried 106FA - same result. 106FF - same result. Chemical Guys Diamond Cut - same result. Even though i've stopped using them, i tried the 3M polishes out of curiosity but even they reacted funny. The only polish that half worked was Menz IP PO9L but even this was causing the pad to "stick" and it was generating alot of heat quickly and dusting like mad - very strange as this ALWAYS works and 99% of the time 3.02 works in the surroundings of our premises where its generally quite warm.
    Already pi$$ed off and time ticking by, i decided to continue with PO9L at low speeds (1200rpm's) moving the rotary quite quickly to avoid building up too much heat and stopping as soon as i could see the paint had corrected, obviously this was leaving feint holograms so i was going to have to go back over the car with the PC afterwards
    I eventually de-swirled half the car and the bonnet before i'd decided enough was enough, i was going to have to switch to the PC as the rotary just didnt want to play ball at all - this would happen on the car with the worst defects i'd seen in a long time! its just aswell that the paint wasnt too hard.
    I changed to the PC and used a Megs Burgundy Cutting Pad (4" Orange LC pad for the tighter areas) with IP 3.02 @ Speed 6, lots of pressure and multiple hits. This was when Rich and Myself came to the conclusion that it probably wasnt the polishes playing up but infact something weird going on with the paint because even by PC the polishes still didnt work 100% - dusting like crazy and proving to be quite difficult to buff off, i had to use a healthy amount of Menzerna's Top Inspection to remove them.
    I had no other choice though so i just gritted my teeth and got on with it, as i de-swirled Rich followed up with his PC,a Megs Finishing Pad and a combination of PO85RD & Blackfire Gloss Enhancing Polish (Rich finds this helps darken the paint ever so slightly) here's a couple of 50/50's during the polishing stage:
    Whilst Polishing the bonnet with the Rotary, 99% of the bird etching was removed but there was still one stubborn stain that was annoying me, so this was sanded with Megs 3000 unigrit...
    ...and then polished out with the PC and a 4" Cutting pad:
    Luckily the owner had the front bumper re-sprayed just recently so it hadnt much time to gather too many swirls, so this was de-swirled fairly easily, as were the headlights:
    before:
    after:
    Onto the rear of the car, the centre section of the spoiler was removed so i could gain easier access to the bootlid...
    ...which was just as fecked as the rest of the car...
    I'd anticipated more wet sanding was going to be needed, but after 2 or 3 hits with the 4" pad this was the result:
    Smooth as glass now :thumb:
    Before the spoiler section was re-fitted, i cleaned it up with a 4" cutting pad and Blackfire Fine Cut Metal Polish:
    I've never been so glad to have been finished the machining stage of a detail, this car seemed to take forever and i never realised just how much i hate using the PC!!
    Never mind, the hard bit was done, so after all the dusting had been done, Blackfire's Wet Diamond Paint Sealant was applied, followed by its Ivory Carnauba Wax. The wheels were sealed with PB Wheel Sealant, tyres dressed with Blackfire Long Lasting Tyre Gel, Arches dressed with Megs All Season Dressing and the exhasut tip was done with Blackfire's fine cut metal polish.
    The interior was also done but it wasnt bad in the first place and to be honest i wasnt in the mood to take any!
    So the car was rolled outside for the after pics before it got dark.....
    Feb 2007
    Aberdeen
    228
    .....aaaaaand then promptly put back inside as it was dull as hell outside and did nothing for the cars finish! :D
    Hopefully the next detail will be "back to normal" where at least one of my polishes work and i can use my beloved Rotary again! :thumb:
    As always, many thanks for taking the time to read the write up
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    A challenge indeed, what a bloody mess man.
    A fantastic finish though, with lots of perseverance, and Rich there too.
    Top job, and it's good to see you're still learning
    ManicMunky's Avatar
    Sep 2006
    Chorley, Lancs, UK
    311
    wow!
    any ideas what went wrong then?
    - Andrew
    Boydie
    very very good work!
    robby's Avatar
    Dec 2003
    West yorkshire
    455
    excellent - bet the owner was pleased with the results
    do you charge by the hour or by the job?
    Aug 2007
    Aberdeen
    119
    You guys are truly brilliant at what you do!
    I'll be taking my car to you shortly to see if you can tidy up my new vehicle
    I cant spell !
    Jun 2007
    North West
    434
    Excellent results as normal - would be interested to see the comment if you post this on Scoobynet !!
    Richard
    Feb 2007
    Aberdeen
    228
    Quote Originally Posted by BaBs
    wow!
    Our latest guess would be that the paint was so dry and "dehydrated" that it just soaked up all the polish like dry skin would do with moisturiser, was certainly a pain in the back side!
    Feb 2007
    Aberdeen
    228
    Quote Originally Posted by robby
    used to be an hourly rate but we recently changed over to fixed pricing mate
    Feb 2007
    Aberdeen
    228
    Quote Originally Posted by rsarjantson
    Richard
    Its posted on there now
    Drmatrix's Avatar
    Vorsprung Durch Technik
    Oct 2005
    London,UK
    160
    excellent job guys this was a tough one well done
    Audi A6 2.4 Quattro SE Cashmere Grey
    Audi Allroad 2.5 tdi (180) Quattro Limited Edition Metalic Silver
    Russboy's Avatar
    Sep 2007
    51
    Top job!!
    Been thinking of treating the Audi to something similar, pretty good at cleaning cars up myself but not to this standard.
    What sort fo £££ do you guys charge?
    Andy D's Avatar
    Sep 2007
    Inverkip, Scotland
    276
    It would be something I'd like to get done too as I don't have the skill or equipment to do it myself
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    [quote=Russboy]Top job!! Been thinking of treating the Audi to something similar, pretty good at cleaning cars up myself but not to this standard.quote]
    Having been inspired by Clark and Richard's work, and having seen them work at first hand I'm going to stick my neck out and say they are arguably the best in the business. They never fail to amaze.
    Russboy's Avatar
    Sep 2007
    51
    Do they have a website etc?
    Its my birthday ons un and I may treat myself to a very shiney car!
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Cheers John, much appreciated feedback.
    Aye, our site is www.polishedbliss.co.uk, and if you look on the services link below you'll find details of what services we offer and how much it costs...
    http://www.polishedbliss.co.uk/acatalog/services.html
    Russboy's Avatar
    Sep 2007
    51
    Opps, didnt realise it would cost that much!! But thats more down to me being naive than you being expensive im sure.
    On the cleaning front I get the car looking pretty good (see My S4 Avant ), probs I have are swirl marks and light scratches really
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Hi Russ, aye, that's what most folk struggle wth, and what takes us two full days to fully take out, hence the cost. Car looks very tidy though, think I remember the days you were on SE when you had a Cupra R? Think I also remember you setting off down the pub route just when the idea for Polished Bliss was being born in my mind? How time flies eh?!
    Russboy's Avatar
    Sep 2007
    51
    Quote Originally Posted by WX51TXR
    Yep, thats me
    was a pretty clean car!
    Still in the pub trade.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Thought so! Still have my Leon, will be going soon though...
    ...still a pretty clean car too, even after 6 years and 90k!
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    only 90k in 6 years???
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    I like to walk too!
    Mar 2005
    Lanarkshire
    That Evo looks as good as new. Top job.
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    looks awsome, I need this =(
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    audi80sport's Avatar
    is it home time yet?
    Sep 2007
    kettering
    116
    when you did this bonnet did you use a block or just your fingers with no backing support for the flat paper? and also try getting a very hard nylon brush or a spur of some kind and clean your mop head with it. i found the main reason it clogs is its got too much 'dead' polish/compound and it just goes tits up thats where the dust comes from...
  28. #27
    Feb 2007
    Aberdeen
    228
    We spurr the pads after every set of polishing is carried out, so theres no risk of any polish building up on the pads mate....
    As for the sanding, i just use my fingers - i find you can inflict deeper sanding marks with a block, which goes against the grain of what alot of people believe but it works for me so its what i use
  29. #28
    Sep 2007
    kettering
    116
    i like to use the ball of my palm if you get me cause i dont know if you have ever done it or seen it using say three fingers you tend to not get uniform flattering and grooves but hay like you said if it works for you lol i used to hate it when it clogged up for no apparent reason and goes and buggers the clear coat up so you have to sit there for half hour flatting it and moulding it back flat!!! bloody thing lol i only use blocks on flat areas and that were with a thin layer of foam between the block and paper and i found that does give excellant uniformity and if you push to hard the foam absorbs the extra pressure give it a go you may like it?
  30. #29
    AL_B's Avatar
    Warrington, Northwest England
    1,564
    Wow! It still amazes me what you guys can achieve.
    AL
    '07 Phantom Black S3 - '07 to now - Bucket Seats, FBMFSW, BOSE, Symphony II+, Cruise Control, Elec Folding Mirrors, Front Centre Armrest, Rear Armrest & Through Load, Interior Light Pack, Luggage Pack, Reversible Boot Mat, Luggage net.
    '02 Silver S3 (225bhp) - '02 to '07
    '99 A3 1.8T - '99 to '02
    '11 Rising Blue Golf R - '12 to now - 19" Black Talladega's
    '52 Black Golf GTi MkIV Anniversary - '03 to '12
