AH FabricationsBadger5
Thread: Coolent level
    Smudge973's Avatar
    Sep 2004
    Harrogate
    128
    Coolant level
    Hello,
    Noticed that my coolant level is on the "min" mark - is it just a simple case of topping it up with water ?
    Phanton Black A4 2.0 TDI Multi, B&O, AMI, NAV, 19" wheels
    Apr 2007
    North London
    63
    mines low too, its says in the book to get it checked at a dealer as this indicates a leak
    although i just want to top it up, dont you have to use a special coolant as it contains a certain amount of antifreeze?
    A3 3.2 Quattro S-line
    shineydave's Avatar
    Jan 2006
    Bradford, Yorkshire, UK
    912
    can't believe that you guys are struggling with this, lol, it's one of the first things my dad taught me when i got a car, checking and topping up fluid levels and checking tyre pressures and treads, etc
    ok, Audi and VW use a longlife antifreeze called G12. it's pink in colour and shouldn't be mixed with conventional antifreeze because it goes a horrible brown colour. you might be able to get it from a local accessory shop, i got some from an independant just up the road from me. i got the neat stuff that you have to dilute 50/50 with water but you might be able to get it ready mxed.
    in my experience you will, over a period of time, always see the level drop but it doesn't mean there's a leak, it's just a bit of evaporation. if i was having to top it up every other day i'd be worried but every 12 months would be normal.
    *another public service announcement from ShineyDave inc*
    Dave
    "If that's the Turbo Fairy knocking tell Her I'm not in"
    Smudge973's Avatar
    Sep 2004
    Harrogate
    128
    Sorted - Found the pink stuff today.. 50/50 with water and topped it up.
    Just wanted to be sure.. . . The maintenance book says "contact Audi when low" so I thought it would be a little different to the norm...
