Chris NottAH Fabrications
Results 1 to 8 of 8
    batwad's Avatar
    Jul 2006
    Beds
    841
    Full alloy wheel clean (56k beware)
    Boy did I have a busy day yesterday. It was the first free weekend I've had in ages where the weather hasn't been completely awful so I thought I'd get round to properly tackling my speckly alloys. Here's an idea of the grime I was up against.
    So off came the wheel - inside was even worse!
    I gave the wheel a good going over with some soapy water and a soft alloy wheel brush and it came up fairly well as usual but there were several speckly spots of stubborn brake dust deposits.
    I'd previously tried AG Intensive Tar Remover, which was awkward to use and had no effect, so the Autobrite Brite Wheels came out for its first outing. Diluted 3-1 I sprayed liberally over the wheel face and the inside. This was left to soak for about five minutes then revisited with the soft brush.
    The caked on brake dust just disappeared! No scrubbing or hard work, the soft brush did the trick easily.
    The insides came up a treat too - I never knew they were white in there!
    So each wheel came off in turn and while I had the rears off I changed the discs and pads as they were getting low. I had both rears done and then the rain came
    The operation moved inside to the dry so I could dress the wheels. Wheel wax went on and was left to dry for five minutes then buffed off.
    Back on the car went the wheels and I was done, about five hours after starting. I was knackered but it was worth it; the transformation was incredible. I can't recommend Brite Wheels enough, such a great product and made the job so much easier. I'd had to think how much elbow grease the job would have required otherwise. I'm told it's not acidic so won't eat away your alloys either, which is nice.
    I'll leave you with a couple of beading shots. I've never had water bead on my wheels before!
    03 A3 (8L) TDi quattro Sport, Aluminium Silver with leather, armrest, cruise, xenons and me at the wheel
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    Manky RS4s, tut, tut.
    Great job there and cracking photos.
    5 hours well spent.
    OutLore's Avatar
    VOIP Dude
    Oct 2003
    Essex, UK
    1,183
    Quote Originally Posted by jr001
    5 hours well spent.
    Good job mate!
    I did the same this Saturday, only I left mine on the car as they are only 2 weeks old...
    Washed, clayed, polished, sealed and waxed. Then drove to Sunderland and back... will see later in the week how easy they are to clean now...
    Spence
    ________________________________________
    Now: 2011 A4 Avant 2.0TDi Black Edition Multitronic Aruba Blue
    Gone at 77k: 2008 A4 Saloon 2.0TDi 140 S-Line Quartz Grey
    Gone at 80k: 2007 A3 Sportback 2.0T S-Line S-Tronic Mauritius Blue
    (4 S-Tronic boxes, 3 Mechatronics Units, 2 Dual Mass flywheels, 2 sets of engine mounts)
    Gone at 32k: 2005 A3 Sportback 2.0TDi 140 S-Line DSG
    Ebony Black
    JGrant1285's Avatar
    Sir Scouser Benitez
    Jun 2006
    West Lancs, UK
    224
    I'm going to do mine too maybe this weekend. I have never clayed them though, which i think i will do. The wheels were brand-spankers in August last year, and usually get covered in brake dust quite quick, do you think claying will be worth while? I'll just use the megs clay i have, as i should have taken delivery of some Sonus Green clay today from Carwashnwax.
    A little advice about the process:
    1.Clean with Megs wheel cleaner & rinse
    2.Clay with Megs last touch
    3.Rinse again & dry
    4.Polish with SRP 7 buff off
    5.Poorboys wheel sealant & buff off
    ^^What do you think about the above process?
    Although i have used the JEFFS Werkstatt kit on the body of my car. I topped the coating of JETT upto 3 coats this weekend, and i am VERY impressed with the colour & beading.
    Should i use this kit on my wheels instead? if so, can someone recommend me a process for this (including the poorboys wheel sealant) please!!??
    Thanks for the help folks, i want beautiful wheels.
    Jimmy
    |B6 A4 1.9 PD TDI Sport | Fully Colour-Coded |18" RS6 Reps | EBC Grooved Discs | Greenstuff Pads | Jabbasport Custom Remap - 141.9hp @ 3683rpm / 368Nm @ 2154rpm | Complete With Drivers Detailing Disorder |
    batwad's Avatar
    Jul 2006
    Beds
    841
    I reckon you could ditch the clay for Brite Wheels. Seriously, it's so impressive how much crud it shifts in the blink of an eye. If you're anal you can then go over and pick the one or two spots left by hand, but to me claying wheels sounds like a complete ball ache.
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    Remember guys that products like Brite Wheels and Megs Wheel Brightener and the likes are for stripping all gunk from the clearcoat outwards on our alloy wheels. Brake dust, some bits of tar and all protective layers of sealant or wax. Also, you prob don't want to use such products very often if they're acidic. They're good if you're doing loads of many-wheeled cars for getting them super clean, but there's generally no need for your own wheels if you're looking after them as much as people on this thread are!
    The mad wheel thread this is!
    Granty, the JEFFS stuff is a treat on the wheels and I would personally spend money on something else for your kit. Put the JEFFS to good use as it has several. As a wheel cleanser, you will notice the difference the PRIME makes and you'll feel the sealant layer it lays down. I used the PRIME after I did the wheel brightener and Tar and Glue remover steps and dried the wheel off. The Trigger, spray once onto a MF cloth and coat your wheel and leave for a few minutes before buffing over. A cracking finish. Just put on extra layers at the time, or after you have dried the wheels at the end of each wash. So easy to apply too. It's now my wheel sealant of choice at the moment and for the foreseeable future. Might try something else in a couple of years!
    It would be interesting to know what someone else thought of the JEFFS stuff on the wheels. Granty, you are the chosen scientist for this one. Hope you don't mind. Report back your results!!!!
    JGrant1285's Avatar
    Sir Scouser Benitez
    Jun 2006
    West Lancs, UK
    224
    ^^ NO probs Jr......will see if i can get cracking on that one over the weekend then!!!
    Think if i get time i'm going to detail the arches also!!
    I'll have you a nice long report written up for you lot too, with many pics!!
    Clark@Polishedbliss's Avatar
    Professional Detailer
    Feb 2007
    Aberdeen
    228
    Personally i think the Jeffs Prime (strong if you have it) followed by the PB Wheel Sealant is the way to go
