EM TuningAH Fabrications
    rxs1407's Avatar
    Mar 2007
    Hampshire, UK
    106
    Scratches On Alloys
    When i cleaned the car at the weekend, i noticed that the alloys do have a large amount of scratches/lines over them.
    The car is a 07 plate, so not that old, what is the best way of cleaning and removing these??
    Thanks Dodge
    A4 Avant S-Line 2.0TDI Leather Trim,Phone Prep, Heated & Electric Front Seats, Audi Parking Plus, Cruise Control, B&O Sound System, Autogym, Boot Liner.......
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Treat exactly the same as you would paintwork; you'll need to polish them to remove the defects. I would start with a finishing polish like Menzerna Final Polish II applied using the white side of a German Pad, and if that failed to shift everything, then I would move down to a light compound like Menzerna Intensive Polish (applied in the same way). Once the correction was done, I'd then seal the alloys with a Wheel Sealant to protect against the effects of brake dust and road grime. Hope that helps, a lot more info on polishing here...
    http://www.polishedbliss.co.uk/acata...es_polish.html
    rxs1407's Avatar
    Mar 2007
    Hampshire, UK
    106
    Quote Originally Posted by WX51TXR
    Thanks very much for the help, will read and get them sorted...
