JMB RetrofitsBadger5
Results 1 to 12 of 12
    Clark@Polishedbliss's Avatar
    Professional Detailer
    Feb 2007
    Aberdeen
    228
    Polished Bliss: Brand new Golf MKV GTI
    Here's another one for you all!
    This write up isnt as detailed as they usually are as we were against the clock for this one so we didnt get as many pics as i'd have liked, so apologies for that :o
    This Golf was tag-teamed by Rich and I several weeks ago:
    To cut a long story short, the car came from the dealers with some nice swirls and various scratches and in an attempt to correct this the dealers only made it worse, so they agreed to pay for us to correct the situation - not often that happens so well done to the owner! :thumb:
    Wash:
    - Pre foamed with Megs Hyper Wash
    - Rinsed
    - Foamed again and then washed with TBM & PB Slick & Sudz.
    - Autosmart Tar & Glue remover on lower panels
    - whole car clayed with Zymol Lehm Clay & Last Touch
    - Rinsed
    - Dried with the Leaf Blower
    Polish:
    Under the Halogens it was quite easy to see the defects, although it was slightly harder to capture them on camera due to the brightness of the paint, but this pic shows the average state of the paintwork:
    Paint readings showed an average of around 90-120 mircons, although there were more areas than i'd have liked that were sub-80 micron level, one area on the off side wing was in the 60's! this was taped off as i wasnt risking striking through on a brand new car, pretty unacceptable in my opinion though for a brand new car to have as little paint as this one did.
    Firstly we tried out 106ff on a polishing pad but the paint seemed rather hard, harder than VW paint normally is, so we stepped up to Menz 3.02 and this did the job, although most panels needed 2 hits @1700rpm's to get them perfect.
    This is the bonnet after polishing:
    Tail light before:
    Tail light after:
    LSP of choice was Blackfire Wet Diamond as the owner wanted something quick and easy to use so he could maintain the finish himself
    Misc. bits:
    Wheels - Poorboys Wheel Sealant
    Tyres - Blackfire Long Lasting Tyre Gel
    Exhaust tips - Blackfire Fine Cut Metal Polish
    Arches - these were fabric so they were left as they were.
    Glass - Zymol HD Cleanse
    Exterior Trim - Meguiars All Season Dressing (buffed off 15 mins later)
    Door shuts - Jeffs Werkstatt Prime Strong
    Again, apologies for lack of pics and the car looks a bit pink in some of them - mainly down to the fact i forgot to switch the halogens off for the afters and the white walls reflect light very well! :D
    None the less, here's the afters:
    Not the greatest write up or pics in the world but thought we'd share them with you anyways, again - thanks for looking :thumb:
    Boydie
    good job lads - what the hell is the golf sitting in in the first pic:??
    JGrant1285's Avatar
    Sir Scouser Benitez
    Jun 2006
    West Lancs, UK
    224
    ^^^^^A Changing mat?????????
    Yet another top-notch detail!!!!
    I wish i could get results like those!!
    |B6 A4 1.9 PD TDI Sport | Fully Colour-Coded |18" RS6 Reps | EBC Grooved Discs | Greenstuff Pads | Jabbasport Custom Remap - 141.9hp @ 3683rpm / 368Nm @ 2154rpm | Complete With Drivers Detailing Disorder |
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    Quote Originally Posted by JGrant1285
    its a washing bay, the water is retained within and then pumped into a tank. They had to do it as part of the lease conditions or something like that.
    1999 1.8 SE A4 100% standard tank, all green.
    Alpine old skool
    Helix RS6 - PHD PRO 4070
    Coral 10" passive setup - PHD 2200
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Okay, water capture system. An inflatable bund is laid out and inflated using an electric air blower. The car is then moved onto the bund, ready for washing...
    You then wash the car as normal, using whatever chemicals are needed (tar and glue removers, wheel cleaners, etc, are all okay to use)...
    Then, once the car is fully washed, you drive it off, and fold the bund to a corner, to deepen the water. This then enables you to use a submersible pump to uplift it into a storage tank, like this...
    Then, once every 3-4 months a tanker comes along and empties the storage tank, taking the dirty water away for treatment and safe recycling. Overall, using this gear adds 20 mins to the wash process, and cost around 2k all in, but it's good for the environment, a necessity under our lease, and easy enough to use on a daily basis. The bund rolls away and is stored in a plastic dustbin, so it doesn't rob us of too much storage space either.
    Boydie
    how can i get my foam gun to do this???
    normski's Avatar
    Nov 2006
    497
    Quote Originally Posted by Boydie
    Same question, amazing...
    Silver 2007 S3
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    Nice finish there Clark.
    I think the photos are actually quite good. It's just a wee bit strange not seeing the usual background that we've been accustomed to.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Product choice through the Auto-Brite lances is irrelevant; all APCs, shampoos and degreasers foam like mad when applied using them. In the above case, Clark used just 2 x 30ml pumps of Megs Hyper Wash in the lance's bottle (filling the rest with hot water). And yes, compared to most other lances, the Auto-Brite ones do create a much thicker, clingier foam.
    Boydie
    can this be fitted to any power hose? ( i have a crappy halfords one)
    do you supply this autobrite lance?
    how much are they?
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Auto-Brite custom make lances to fit most common types of pressure washer, best bet is to give them a call for a price and info. Here's the web address...
    http://www.autobritedirect.co.uk/
    Boydie
    thanks mate :D
