EM TuningJMB Retrofits
    Spudgun's Avatar
    Apr 2007
    Warrington
    53
    Inside of the Windscreen
    Does anyone know of any kind of Tool , Knack , Trick or Technique for cleaning the inside of your windscreen.
    Particularly the bottom edge by the dash board.
    Its a Royal Pain in the arse !
    jr001's Avatar
    Oct 2006
    CENTRAL CALEDONIA
    374
    Some people might do the dash first, others may do the inside windscreen first. I don't suppose it really matters. It can be a nuisance when you get 'overspray'. However, there's prob no need for any special tool.
    I find it best to spray chemicals onto MF cloth not only in the centre of the cloth but at the edge say nearest the windscreen when I'm getting into the footery bit right up against the window. It's not difficult but I don't mind if I get it slightly wrong in my own car. It's not the end of the world it will wipe off easily anyway. The secret is spraying the correct part of the cloth really.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    As above, always spray onto a mf towel, then wipe (rather than spraying products directly onto the glass, that just makes a mess), and just fold the towel to get into the edges. No other magic I can suggest!
