EM TuningAH Fabrications
Results 1 to 12 of 12
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    need advice.. detailing 'the tank', help/suggestions please
    So my poor old tank needs a decent treatment. I am considering a portercable at the end of the month (the sonus package from autopia i guess).
    Last week i clayed her (with meguiers clay kit) washing before and after with goldclass shampoo, the followed with the meguiers stage 2 and then gold clearcoat wax.
    I know the meguiers stuff is pretty 'mainstream' stuff, but the results it gives over turtle wax (for example) is impressive. I do, however, still have a lot of swirls and webbing, as well as a few deeper scratches...
    heres a few (bad) pics to give you an idea olf the colour, and the swirling on the roof...
    http://bobbycock.com/clayed07/
    So, what do you recommend? realistically i dont want to spend more then about 50~ for some decent cleaners/polish sealer and wax. I already have the microfibre cloths etc. This is just paintwork to worry about at present, wheels need a refurb so they can wait.
    thanks in advance peeps.
    1999 1.8 SE A4 100% standard tank, all green.
    Alpine old skool
    Helix RS6 - PHD PRO 4070
    Coral 10" passive setup - PHD 2200
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    any ideas?
    Alpine old skool
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Wow, tight budget for all those steps, but here's an idea. Working by PC, I would firstly go with Menzerna RD3.02 Intensive Polish using a light cut pad. This will cost 16.85. I would then go with Menzerna 85RD Final Finish using a polishing pad. This will cost you 14.95. Finally, I would go with Blackfire Wet Diamond All Finish Paint Protection, which will seal the paint and give a wet and glossy look that will really suit the colour of the car. This will cost you 21.95. Just a few quid over budget, but if you though the Meguiars gear was good then these products will blow you away.
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    I'll extend the budget if needs be, i want to utalise the products i already have, just find a decent polish or something to work out the swirls and spiderwebs. then a decent wax to bring up the metalic a lot more.
    Thanks for the suggestions,wx. I assume these really need PC'd on to get the best resaults? what kinda speeds am i looking to use?
    Alpine old skool
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Aye, both Menzerna polishes mentioned above need to be machine applied, using light to moderate pressure at speeds 4-5 (after being spread at speed 1). If you want to try to work by hand, the standard version of Menzerna Intensive Polish applied using the white side of a German Pad is the best way to go, but be aware that you won't achieve full correction working by hand.
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    time to order a PC then! wheres best/cheapest to get one?
    Alpine old skool
    Clark@Polishedbliss's Avatar
    Professional Detailer
    Feb 2007
    Aberdeen
    228
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    thanks, already ordered with a 15% discount code from them :D
    then ill be raiding the PB store soon for some supplies
    Alpine old skool
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    seeing as the Menzerna RD3.02 Intensive Polish is out of stock pretty much world wide. can you suggest an alternative please. Looking to place an order today/monday of polish, sealant, pads
    Alpine old skool
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Sadly, very little else comes close, but looking farther afield, Chemical Guys Diamond Cut Polishes are okay, and 3M Perfect-It Machine Polish is also one to check out (and probably easily available from your local bodyshop supplier).
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    the PO85RD3.02 no good then?
    Alpine old skool
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    Still not got any in stock ive got money burning holes in my pocket. Any one want to suggest an alternative bunch of products that are instock in the UK right now.
    Alpine old skool
