EM TuningVolks Autos
    clcollins's Avatar
    Mar 2004
    Lancashire
    276
    Bird muck etching
    Hello all, how do you remove/fix paint etching caused by bird droppings?
    Thanks in advance
    Neil_S's Avatar
    Jan 2006
    Hampshire, UK
    248
    If the etching is not too far into the paint then wetsanding and/or machine polishing are in order.
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    Etching is often very deep, and thus impossible to fully correct. In order to attempt correction you need to polish the area using a polishing compound like Menzerna Intensive Polish, either by hand using a German Pad, or by machine using a polishing pad. Whilst polishing usually improves the look of such defects, it doesn't always fully correct them (you can try wetsanding, but you need a paint thickness gauge in order to do this safely). Sadly, etching is usually deeper than the thickness of paint that can be safely removed by polishing. Another option is to try and hide it to some extent by using a glaze such as Menzerna Finishing Touch Glaze; again, the results won't be perfect, but the fillers can help to hide the mottled effect a bit.
