EM TuningVolks Autos
Results 1 to 7 of 7
    Clark@Polishedbliss's Avatar
    Professional Detailer
    Feb 2007
    Aberdeen
    228
    Polished Bliss Vs Golf Mk2 G60 + Zymol
    This stunning Golf belongs to Kenny, a member of DW (G60 VV).
    He had contacted us a while back about preparing the car for the up and coming show season. I vaguely knew of the car before hand as my dad is friends with Kenny's and one of my mates did some of the paintwork on the car and to be fair they did a very good job (full re-spray)
    Although, as to be expected there was the odd one or two ( ) holograms (see the b-pillar) that could be seen before i had even washed the car:
    So, the car was Foamed as usual and left to dwell for 10/15 mins before being rinsed off. It was then foamed again and then washed with the TBM, tar spots removed with T&G remover (no need for claying), foamed and then rinsed again before drying.
    Once inside i could see what the biggest problem was going to be, The whole car was covered in very bad Micro-Marring left from the Rotary Polishing the car received at the Bodyshop,some of it was pretty deep too, looking quite similair to the marks left in paint when hit by egg shells:
    Note how the Marring robs the paint of any real clarity.
    I then took paint readings and the car ranged from around 280 all the way to a generous 1682 microns!
    Luckily, the car wasnt too bad for actual scratches (the bonnet was the worst but even then you couldnt really see them for the micro-marring that was present) so i decided to try the least aggressive of the finishing polishes on a finishing pad @1200rpm to gauge how soft/hard the paint was. This made a minor improvement but would have needed at least 2 or 2 hits to achieve a finish to keep me happy so i stepped up to the slightly more aggressive finishing polish on a polishing pad @1500rpm and this took care of just about everything after the first attempt. Luckily this re-spray seemed to be a bit softer then the S3 i did last week although some areas still needed a couple of tries where the marring was especially bad.
    Areas like the A & B Pillars, door surrounds and wing mirrors were done with the PC as the rotary couldnt squeeze into those small surface areas
    After the Polishing was done i then HD Cleansed the Paint and Glass and applied Zymol carbon by hand to all paint and exterior plastics/window rubbers etc. I then dressed the tyres and arches, sealed the wheels and polished the exhaust.
    The car was then given one final wipe down with Zymol Field Glaze to remove smears and oils etc
    And here are the afters:
    11 Hours work in total for what was pretty much a straight forward detail for once
    Thanks for looking
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    Absolutely stunning as usual Clark. Now where did I put that polish...?
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
    Defratos's Avatar
    Youre Dethpicable!!
    May 2004
    London....Relocated to the Mid East
    2,230
    Once again a briliant Job mate. I'm def coming over at some pont between now and summer
    2002 S3 BAM | Jabba Re-Map | Uprated Haldex | Koni adjustable coilovers | Neuspeed ARBs | Powerflex Bushes | ECS tie-bars | Dog bone | Eibach spacers | TTDA | T'Dynamics DV | Dieselgeek short shift | Toyos | MIJ Custom Exhaust | Sound system | Security Tints |
    Audi S3-BAM
    Olly_K's Avatar
    Administrator
    Jun 2000
    2,643
    fantastic, but isnt that a rallye ?
    rallyes were g60's with flared arches, g60's had the g60 lump but in a normal mk2 ?
    Drmatrix's Avatar
    Vorsprung Durch Technik
    Oct 2005
    London,UK
    160
    Once again a brilliant job clark
    i will be looking for a good body shop in east london to deal with a dent i just got then ill have to arrange to get mine done for the summer as well.
    any one know a good body shop in london?
    Audi A6 2.4 Quattro SE Cashmere Grey
    Audi Allroad 2.5 tdi (180) Quattro Limited Edition Metalic Silver
    Feb 2007
    Aberdeen
    228
    Quote Originally Posted by Olly_K
    Yes you're right mate, it is a Rallye
    Boydie
    stunning! paint looks edable! (spl)
    the colour of the RS in the first pic looks awesome too!!!
