EM TuningChris Nott
Results 1 to 13 of 13
    Herby1's Avatar
    VAG All the way
    Oct 2006
    303
    Meguires Quik Clay
    What do people reckon of this product? any good? its supposed to be awesome bit of kit but i would like to see peoples verdict on it?
    Anyone used this stuff?
    C_Audiboy's Avatar
    Vroom Vroom
    Nov 2004
    Glasgow
    811
    I used it for the first time about 2 months ago and like you say, it is truly awesome.
    I couldn't beleive how good it leaves the paintwork. Removes all the tar and gunk that the car picks up especially in winter. Just do a panel at a time, and make sure you use the supplied spray to keep the area you are working on wet. You'll be amazed.
    987 Boxster 2.7 (05) - Current
    A3 2.0T Quattro S-Line (55) - gone
    S3 Quattro (02) - gone
    WX51TXR's Avatar
    Polished Bliss
    Mar 2005
    AB51 0TH
    1,450
    The best beginners clay kit by miles... it's what I learnt to clay with, and what I recommend to all customers wanting to try it for the first time. It's a good value kit, and easy enough to use, the real benefit being the clay is very mild and hard to go wrong with. Here's a guide that will help you get the best from it...
    http://www.polishedbliss.co.uk/acata...des_clean.html
    silver75's Avatar
    Big Ron
    Sep 2005
    at work
    3,243
    I used it for the 1st time last week when we had a bit of sun, not sure if I used it properly... how much of the quick detailer stuff do you put on before you use the clay? When you put loads on the car the clay just slides over the paint and when you use a little it doesnt...
    Smart Roadster 03
    Ford Sportka 05
    Neil_S's Avatar
    Jan 2006
    Hampshire, UK
    248
    Yep, the clay is supposed to aquaplane over the paint, make sure you warm up the clay first with your hands so it is nice and malleable too.
    Then spray the panel and slide it over the surface (it should glide and not stick).
    The contaminents should be pulled out/sheered off by the clay.
    Check the clay regularly and when it starts to get a little dirty, fold it over and kneed some more to create a fresh piece.
    If it is dirty, discard and get another piece (for a typical claybar like megs you can easily divide this into 2 or 3 separate pieces).
    If you drop your clay bar, discard it.
    Jul 2006
    1,562
    Excellent product!!!
    I'm now buying up most of their range LOL!!! It's all so effortless and easy to use.
    Nov 2006
    liverpool
    703
    i was also amazed first time i used it...
    Sinny71's Avatar
    S55 LKS
    Jan 2007
    North East
    777
    I just bought some last week so am liking everyone saying how easy it is. Got it to tackl my Mam's car as opposed to mine though so I can use hers for a practice run. lol
    2004 1.9TDi A4 Avant Sport, GmbH bodykit, DPM Remap, Fishscale Alu trim, RNS-E
    Nov 2006
    liverpool
    703
    lol good thinking dude- just make sure u use plenty of lube and your cant go wrong
    Niknak's Avatar
    Oct 2006
    manchester
    864
    Fantastic product really easy to use and the results are
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,675
    What everone else said.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Herby1's Avatar
    VAG All the way
    Oct 2006
    303
    sweet il get it then lol
    cant wait to clean my car at the weekend! how sad am i.....i actually look forwarding to giveing her a good bath!
    buckas's Avatar
    Sep 2006
    south west wales
    750
    Quote Originally Posted by chris_20
    ain't that the truth
    p.s not in a gay way lol
