WX51TXR
Polished Bliss
- Joined
- Mar 6, 2005
- Messages
- 1,452
- Reaction score
- 16
- Points
- 36
- Location
- AB51 0TH
- Website
- www.polishedbliss.co.uk
We did this RS6 last November, but it's a good example of what we do and what standards we work to. Another detailer had only recently detailed the car, but the owner was unhappy with the results, so called us in to have a look at it. On the phone the owner had told us that the paint correction work done by the other detailer was good, and that it had been the little things that had let the job down, such as not cleaning polish residues out of the panel gaps and shuts, and not polishing the exhaust tips, etc. However, just to be on the safe side, we recommended allowing up to 12 hours for the work, and as it turned out, it was a good job we did! Heres the process and pics
Before
Heres how the car looked when we arrived
Overall not too bad, just the usual autumn grime, but I knew the alloys were never going to be able to be brought up 100% due to the kerbing...
Wash
Wheels, arches and all plastics pre-treated with P21S Total Auto Wash
Whole car foamed with mix of PW Slick & Suds via the Gilmour
Whole car rinsed off with the Karcher, arches blasted out
Whole car washed by hand using two buckets/Megs Lambswool Mitts
Whole car dried with PW Waffle Weave Towels
The P21S pre-treatment didnt shift as much of the baked on brake dust as I would have liked, so we then used Megs Wheel Brightener cut 4:1 to further clean up the alloys. The owner had specifically asked us not to get any strong wheel cleaners on the brake components, so we did the opposite sides of the alloys first, then rolled the car forward a couple of feet and did the other side this allowed us to fully clean the rims whilst completely avoiding the brake components. Here are the final results
Clean
The fingertip test revealed no bonded surface contaminants, other than a small amount of paint spots on the nearside front door, so no major claying was done.
Interior
The dashboard, air vents, crevices, etc, were all dusted down with a Meg Slide-lock Brush and then wiped down with a damp work towel. All carpets (inc. the boot) were then hoovered. All plastics/vinyl was then wiped down with PW APC and work towels. The mats were brushed using a Megs Upholstery Brush and hoovered, and a few random grubby bits on the seats were wiped off with PW APC and work towels. The windows were then cleaned with Megs NXT Glass Cleaner and work towels, and the leather seats finally fed with Megs Leather Conditioner applied using a German Pad. The door shuts were treated with JEFFS Werkstatt Prime Acrylic.
Engine
The engine bay wasnt bad at all, just the usual build up of grime and debris, so I opted to wipe it down with a P21S solution (cut 10:1) and work towels, and then dressed all the plastics with 303 Aerospace Protectant. The engine cover had a fairly severe scratch on the main cover, so what with it being carbon fibre, I machine polished it with a 4 polishing pad and Blackfire Finishing Polish. This greatly reduced the severity of the scratch, and left the engine cover with an awesome gloss. I then sealed it with JEFFS Werkstatt Prime Strong, and finished off by treating all of the visible painted surfaces to a coat of JEFFS Werkstatt Acrylic Jett Trigger.
Before
After
Polish
We then moved the car inside the garage, taped off all the trims with 3M 3434 masking tape, and had the first nasty surprise of the day
:doublesho
It didnt get much better elsewhere either
Fortunately most of the car was sitting a lot higher in the usual territory of 100-120 microns, but some areas had obviously been worked hard, and how the hell 52 microns still had any clear coat left well never know!
We proceeded to work our way around the car, taking a side each, and me doing the bumpers with the PC while Clark tackled the horizontal panels with the Makita. Clark found Blackfire Finishing Polish and a mix of Megs Polishing and Finishing pads sufficient to achieve 95% correction on his sections, while I found an initial attempt with PowerGloss and a 4 light cut spot pad followed by Blackfire Finishing Polish on a 7.5 orange light pad did the trick for me. Just goes to show what a rotary can do, and I still cant wait for my Metabo to arrive! Why only 95% correction I here some of you ask? Deeper random scratches unfortunately, on almost every panel, which was a bit of a bummer, but as always, you can only do so much safely without compromising the long term integrity of the clear coat. Heres some shots
Before
After
Before
After
(notice I couldnt get the machine into some awkward areas, hence no correction)
Combined image (left before, right after)
A lot of folk on here seem to be using way too much product when using the new generation of polishes designed for scratch resistant clear coats, whether by PC or rotary, so here is a guide to what I use to do a largish area, such as the top half of an Audi door
The above pad is also getting near to the point where I would either swap it for a fresh one or wash it out in order to avoid clogging and micromarring. Keeping the foam fresh gives better results.
More paint defects visible in this shot, not only normal wash marks and deeper random scratches, but also some serious holograms, which required two attempts with PowerGloss and light cut spot pads followed by a final going over with Blackfire finishing polish and a polishing pad to fully correct
Before
After
Before
Wash
Clean
Interior
Engine
Before
After
Polish
:doublesho
Before
After
Before
After
Before
After
