AH FabricationsJMB Retrofits
Results 1 to 7 of 7
Like Tree1Likes
  • 1 Post By sabaxter
Thread: Cleaned My Engine Bay
    sabaxter's Avatar
    Jun 2013
    293
    Had a go at cleaning my engine bay today and I must say it turned out well!!
    I used GUNK degreaser and Meguiars engine cleaner and agitated with a paintbrush and rinsed lightly with water. I then used Fenwicks cleaner and sprayed everywhere then wiped with a microfiber cloth. I did my usual trick of applying wd40 to moving components to provide some lubrication and extra protection against the elements.
    Once rinsed I started the car to allow the heat to dry the majority of the components. I gave the plastics a rince and a clean with wash and wax and used Meguiars plastic protector to give a nice sheen. Took me about a hour and im well impressed with the results.
    Cheers, Shaun.
    Sandra likes this.
    Oct 2012
    East Kilbride
    343
    looks good, well worth doing...
    sabaxter's Avatar
    Jun 2013
    293
    It's fair to sat the engine is cleaner than the rest of the car!
    A4 B6 1.9TDI Avant in Ming Blue. S Line Bumper and Door Blades, Cruise Control, RS4 Carbon Fiber dash inlays, Passat Projector fogs with 55w 8000k HID, Carbon Wrapped Grills, Cupra Splitter, BBS LM reps 19", Heko Deflectors, S Line Spoiler, All LED interior Lights, Auto Dim Mirror, 1.8t exhaust, HD Touch screen headunit GPS DTV IPOD CD DVD, Front Armest, Rear Cupholders, Focal Sub, Focal Amp, Hertz 4ch Amp, 2x Focal Access 165a1 Components.
    Schizophonic's Avatar
    Jul 2013
    Northampton
    320
    So scared to ruin any electronics
    LukeTripod87's Avatar
    Apr 2009
    Kent
    325
    Looking good! As long as you cover up any electrics and air intakes and don't use too much pressure with the water you'll be fine!
    2010 S3 Sportback
    Miltek cat-back non res / soon to be wrapped!!.....
    **Message for parts enquiries in Kent**
    ShaneSun's Avatar
    Oct 2013
    Kildare, Ireland
    23
    Follow ShaneSun On Twitter
    Looks spotless! Great work!
    Current: Audi A4 B8 S-Line
    sabaxter's Avatar
    Jun 2013
    293
    Thank you for the comments. I'm going to start cleaning the engine and bay more often, with the car getting older and more miles if I'm unlucky and spring any leaks it will be easier to spot and also it stops crap jamming up moving parts.
    you should never need to use a jet wash on your engine. If you take your time with a brush and agitate the grime using gunk or a similar product you will be fine. When you are rinsing use a hose on a shower function and liberally apply. Don't focus on one spot for more than a few seconds. Just pass over the bay a few times until suds have gone and fire her up to dry some parts.
    do not out start your engine whilst your in there or you will be waving goodbye to your fingers! People only start the engine when steam cleaning and this is more likely to damage electrics. Hope this helps.
    regards shaun
  1. steam cleaning engin bay wider archs and resprays
    By FumaS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th April 2009, 18:22
  2. Cleaning the engine bay
    By GlasgowRangers in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th November 2008, 20:33
  3. Cleaning engine bay?
    By J7-AUDIA3 in forum Detailing
    Last Post: 20th February 2008, 10:35
  4. How To Clean An Engine Bay
    By ardandy in forum General Chat
    Last Post: 2nd October 2006, 21:02
  5. Engine bay cleaning...
    By ea4771ddy in forum Detailing
    Last Post: 16th April 2005, 16:51
