Badger5AH Fabrications
Results 1 to 12 of 12
Like Tree3Likes
  • 2 Post By Paul Holtom
  • 1 Post By R90 STL
Thread: Detailing Advice for Novice
    Paul Holtom's Avatar
    Jan 2014
    11
    Add Paul Holtom on Facebook
    OK so I have a new S3 on order in Misano Red and whilst counting down the weeks till delivery thought I would use the time to sort out cleaning stuff for it. Whilst I have always cleaned cars myself rather than use say a car wash I want to spend a bit more time and effort on this one to keep it looking great.
    Plan is to get it pro detailed from new and then maintain myself on a weekly basis. Due to where I live access to pressure washer is difficult so it will be a hand wash and polish.
    This is what I already have, is there anything missing or anything that would be better for the colour paint.
    Wheels
    Valet Pro Bilberry Wheel Cleaner
    Poorboys Wheel Sealant
    Bodywork
    Valet Pro Citrus Pre-Wash
    Chemical Guys Maxi Suds Shampoo
    Autoglym Tar Remover
    Collinite 476 Wax
    or
    DoDo Juice Hard Candy
    or
    DoDo Juice Need For Speed
    Glass
    G-Techniq G6
    sabaxter's Avatar
    Jun 2013
    295
    As with all detailing products are recommended purely by personal preference. Personally I find meguiars ultimate range are cost effective as well as being effective at keeping paint in great condition.
    Personally I only use a pressure washer to use my snow foam, I believe pressure washers can be dangerous although others would recommend there use.
    You have a great selection of detailing products there so I would try them to see if they achieve your desired finish. If not try the meguiars ultimate compound, polish and wax.
    There is my input and I'm sure many other members will recommend products that they use. Try different products and see what is best for you or ask your detailed what he/she recommends
    Regards Shaun
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,088
    I'm with Shaun, I think you have a good selection there. The only thing I could see that was missing was a quick detailer. I can recommend:
    FinishKare #425 - Ultra Slick Polywipe
    or
    Chemical Guys - Synthetic Quick Detailer
    I've also used Gtechniq C2v3 after washing. It's a spray sealant but as it's water based a lot of people use it in a QD style.
    If you are having your car pro detailed I would ask the person doing it what they recommend as a top up. Also if the wheels have been pro detailed and sealed, you shouldn't need your wheel cleaner. Shampoo and water will be fine. Basically let the pro do their job and ask them what you should do to keep on top of it.
    LukeTripod87's Avatar
    Apr 2009
    Kent
    325
    If you are getting it professionally detailed new then I'm guessing it will be polished then sealed/wax afterwards. Depending on the car's usage the paintwork only needs to be polished 2-3 times a year, it's the wax/sealant that needs to be used more. A couple coat's of Collinite 476 would last you a good 3 or 4 months. Giving the bodywork a good spray of quick detailer after every time you wash it will help keep it looking shiney!
    2010 S3 Sportback
    Miltek cat-back non res / soon to be wrapped!!.....
    **Message for parts enquiries in Kent**
    R90 STL's Avatar
    Apr 2013
    Glasgow
    551
    Follow R90 STL On Twitter Add R90 STL on Facebook Visit R90 STL's Instagram Channel
    not using a pressure washer or hose of some kind prior to hand washing is just asking for swirl marks IMO
    Audi A3 Black Edition 2.0 Tdi DSG - Black Audi rings - Private plate - RS3 grill - C Quartz ceramic coating - Stage 1 remap - 50mm H&R Springs - SOLD
    MY11​ Imola Yellow S3 - Black Edition - DSG - RNS-E - Sunroof - RS3 grill - H&R 25mm springs - Shark Performance stage 1
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,088
    Could use Optimum No Rinse or Dodo Low on Eau at least as a pre rinse to help. They work well if used correctly.
    Low on EAU Test - Detailing World
    Optimum No Rinse vs. VW Jetta
    Jan 2014
    11
    Have access to a hose, just not the electric for a pressure washer.
    R90 STL's Avatar
    Apr 2013
    Glasgow
    551
    that would be much better than just going straight at it with a hand wash! just make sure you get yourself 2 buckets with grit guards and a lambswool wash mitt to minimise damage to paint
    Jan 2014
    11
    Two buckets and Mitt already have and just ordered some Angelwax QED and Elixir so should have everything now.
    scotty76 and RobbieWebs like this.
    R90 STL's Avatar
    Apr 2013
    Glasgow
    551
    nice one. be aware that detailing is a slippery slope haha you will be constantly buying stuff
    Welshquattro likes this.
    Sep 2013
    South Wales
    369
    You have got most of the basics. Spray over with the Citrus pre-wash and hose off after ten minutes before using the buckets and mitt!
    Dimokslis's Avatar
    Oct 2011
    Wembley/LTU
    48
    Add Dimokslis on Facebook Add Dimokslis on Google+
    Will Revitalise paint correction system | Auto Finesse help to get rid off of all those:
    Or are there better/cheaper ways to to that?
    I've got clarke 6 speed polisher, that I will use for the job, and it will be very first time, that I am doing anything with body paints.
    Any advice welcome.
    Thank you.
  1. Replies: 47
    Last Post: 25th April 2012, 12:11
  2. Novice detailer - advice
    By Wozski in forum Detailing
    Last Post: 21st May 2010, 20:33
  3. Replies: 4
    Last Post: 24th April 2005, 17:35
  4. Replies: 0
    Last Post: 13th March 2005, 11:52
  5. A4 2.8 Quattro pricing advice for a newbie please!
    By Skaj in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th October 2003, 18:38
