EM TuningChris Nott
Results 1 to 7 of 7
Thread: Wheel Wax
    concoursneil's Avatar
    Aug 2003
    Plymouth UK
    327
    Wheel Wax
    Just bought new set wheels want to wax them up before putting them on
    Has anyone tried this
    http://www.wheelwax.com/
    [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    Buster's Avatar
    Dec 2005
    Aberdeen
    169
    Re: Wheel Wax
    Haven't tried that product but have used wheel wax in the past on diamond cut wheels. They still pick up brake dust but does acctualy rinse off more easily.
    OutLore's Avatar
    VOIP Dude
    Oct 2003
    Essex, UK
    1,183
    Re: Wheel Wax
    Often thought about using some of this stuff - its available from cleanandshiny, but is damn expensive. Worth it providing it works though.
    Not sure if it's any different to a "normal" wax......
    S3_MCD's Avatar
    Dec 2003
    Bristol
    390
    Re: Wheel Wax
    I use my car wax (auto glym)
    Dec 2005
    Norfolk, UK
    24
    Re: Wheel Wax
    I use Kleen Wheels Aq metal mate which is a special polymer and coats the wheel forming a barrier between painted surface and the elements.
    I have used it for a while now and it works best on new wheels as it needs to bond.
    I have also used turtlewax brake dust barrier but this doesn't last very long and needs to be repeated regularly. I have only applied the Kleen wheels once and its effect does not wear off.
    Brake dust still collects but it doesn't stick so is very easy to wash off. - No need to use the harsh cleaners again.
    To be fair I do clean my car regularly but it makes it much easier
    It isn't cheap but worth it IMO
    try www.kleenwheels.co.uk
    RGB
    Aug 2003
    Plymouth UK
    327
    Re: Wheel Wax
    I could say i a bit obsessive on the cleaning too :-)
    So wheels dont get that dirty really but just thought it may add bit more protection against the dreadded salt too
    Jan 2005
    50
    Re: Wheel Wax
    I have used this and it really does keep your wheels cleaner.......I would recommend it!
