Chris NottMonster Motorsport
Results 1 to 18 of 18
Like Tree4Likes
  • 2 Post By 45bvtc
  • 1 Post By quattrojames
Thread: Removing badge adhesive....
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,704
    .... but not normal adhesive. My badge was on the wrong side, so I know it's been glued on with something. It has come off ok, but what's left behind is like a sealant that has dried hard. Very hard. I can chip it off (to a point) but it's taking the paint off with it. Currently the only damaged area I can cover with a new badge, (a small longer quattro shaped style one) but I'm out of ideas. Only option I can think of is to buy a new A6 badge! I really need something that will dissolve the sealant.
    Any thoughts?
    Pepsi's Avatar
    Nov 2012
    Lancashire/Yorkshire
    82
    i used auto glym tar remover for my badges. worked well, just have to let it soak in for a couple of minutes then pretty much wipes off..
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    I've always used Caramel wheels.
    Stripe Removal Wheel Toffee Caramel Do Nut Drill Glue 1 | eBay
    Some polish and what not afterwards to clean it up.
    A4 B5 Double Din, RNS-d, TMC, Full Sports Leather Heated with Leather Door Cards and Lower Door trims all for sale.
    Audrey's Build Thread
    RIP Audrey. She's being broken down.
    New Car, New Thread.
    Scott's Akoya Silver A8
    Mar 2008
    Dorset
    13,704
    Scott, I'll speak to you.
    This stuff has no apparent absorbency though, it's a similar feel to tile grout. I have soaked it in in white spirit, which I imagine is what AG tar remover is based on to but no avail.
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,655
    It works on the drive stuff as well.
    I've not found any thing that its not been able to remove yet.
    Just don't hold it on or it will get hot and effect the paint.
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,209
    Follow Brodster On Twitter Add Brodster on Facebook
    If it doesnt absorb then chemicals will not work. You may have to use a non metallic scraper made out or paxolin or perspex. It may scratch the surface it may not all depends on how hard the glue substance is. If it scratches then a quick detail on the tailgate will suffice.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/VCDS/Wagner
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,094
    White spirit, soak and leave for 10-minutes, then soak and leave for 10-minutes, then carefully with finger and thumb 'push/peel' off the adhesive. DO NOT use anything sharp or abrasive!
    Apply a decent coat of polish and buff-off, 'tis easy...
    Mar 2008
    Dorset
    13,704
    I've debadged lots of cars, and you're right it is easy. But not with this, which isn't the usual adhesive. I could soak this for an hour in white spirit but it wouldn't matter because it's non absorbent....
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,094
    Ok, I'm in Staffordshire and will be happy to spend a few hours and do it for you/together.
    Your badge adhesive residue looks EXACTLY the same as mine did when I 'dental-flossed' mine off my 2011 RS3 so I don't see yours being any different.
    You could maybe try some Methylated spirits also, as I may (?) have done; but whichever, it will/does soften eventually and sufficient to roll-off with finger and/or thumb.
    Did the same on our TT, and a few other RS3's: same process, same effect i.e., that gooey-stuff did come off without paint damage.
    More than willing to give you my time...
    Otherwise be patient and do it again, and again, and again if necessary but it WILL come off!
    quattrojames and rjm180 like this.
    Mar 2008
    Dorset
    13,704
    Thanks for the offer, I'm in Dorset though so it's not really a feasible plan!
    I'll have some more time on Friday, I'll resume soaking in white spirit then and let you know how it goes. Thanks for the advice.
    45bvtc likes this.
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,209
    Have you tried fishing gut to get underneath it and slowly cut thro it??
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    the living room
    3,595
    right james, try this,
    just done the 5 and this is what i done, ok, not exactly the same problem, but give it a shot dude!
    hair drier the gum, squirt WD40 on the gum as you do it with rag underneath for 5 mins, rubbing as you heat, try fishing line, your finger nails etc to pick of the excess, and keep heating as you pick!
    wd 40 does have a purpose!
    once off, polish or T cut the shaddow and, voila! gone.
    manor13's Avatar
    Aug 2013
    West of Lothian
    306
    I used hair dryer then autosmart tardis to remove mine, that will def remove it. tardis is only avail in 5L but you can buy from the decanters on ebay 250ml will suffice.
    2006 8P Audi A3 2.0 TFSI Quattro Sportback SE / 2013 8V Audi A3 1.6 TDI Sportback
    45bvtc's Avatar
    Sep 2007
    Staffordshire
    1,094
    Did it work for you? Job done?
    Jun 2013
    108
    x2 with WD40
    Mar 2008
    Dorset
    13,704
    Quote Originally Posted by 45bvtc View Post
    Unfortunately the ebay seller sent the wrong item, and then by the time the correct one arrived and it lined up with my days off it was time for torrential rain! I have soaked it several times in both white spirit and WD40 and it doesn't appear to have softened it all.
    I'll update in due course when I've managed to try it.
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    the living room
    3,595
    Don't forget to use the hair drier! Very important 😁
    Mar 2008
    Dorset
    13,704
    None of the spirits I tried touched it, white spirit, WD etc, the only thing I didn't try was Tardis (as I didn't have any). It was completely impervious, so wouldn't absorb any kind of liquid.
    Finally had a go with the caramel wheel today.
    It did the job, probably took me a best part of an hour as I kept it well soaked with Last Touch detailing fluid as I was terrified of burning the paint! What you can see is the paint that came off when I lifted the badge the first time, so it's as good as it's going to get. I'll cut the paint back and polish it up and that should hide the worst of it.
    When that's done and the weather is kinder I'll put this on which should detract from it quite a lot anyway. Thanks all for your help
    ScottD3 likes this.
  1. How to remove badges (Superglue)????
    By blanc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th May 2011, 15:15
  2. RS4 Genuine centre cap, Removing badge
    By paul26982 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st September 2009, 16:16
  3. Removing badges
    By dirk technic in forum Detailing
    Last Post: 23rd February 2009, 13:52
  4. removing badges
    By JP in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd June 2006, 15:48
  5. What to use to remove spray adhesive glue?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2004, 14:03
