JMB RetrofitsBadger5
Results 1 to 14 of 14
Like Tree4Likes
  • 1 Post By A3_130
  • 1 Post By desertstorm
  • 1 Post By matts1
  • 1 Post By matts1
Thread: Restoring your own alloy wheels?
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Guys
    Dont know if this is the right section to post this in or not... But i'm looking to restore (Tart up) my original S3 alloy wheels, but they are not in a bad enough condition to justify paying to get them professionally done....
    I've seen a few boys doin their own wheels and interested in the processes of doing it... I've just got the usual scrapes, I seen guys using a small bit of filler then painting and some of the results have been great... 1 of the rims does have a bit of laquer peel on it tho and would need professionally refurbed if I couldnt do it myself...
    any tips and pictures of the process would be great guys, cheers...
    Audi history... Brilliant Red 2.0tfsi Quattro, Sprint Blue S3...
    dolcevita4's Avatar
    Feb 2012
    Durham
    74
    How I've done mine before:
    1. take wheels of the car and get air out (if you have access to the tire machine take the tire off)
    2. if doing it with tires on, use paper to wrap around tires
    3. use 400 grit wet and dry sand paper and sand the wheel down
    4. fill in any gaps with alloy filler
    5. sand down where filler was used with 400 wet and dry
    6. sand down all wheel with 600 wet and dry
    7. two layers of primer (i've used grey one)
    8. two or three layers of paint ( better to go for more layers and gently spray them rather than sanding them down again ) - make sure when your spraying you keep the appropriate distance
    9. two layers of clear lacquer
    it's simple but time consuming. make sure you paint in dust free area and after sanding down make sure the wheels are dry and clean.
    S3_Jacko's Avatar
    Jul 2010
    Glasgow
    1,290
    Thanks mate.... What colour paint did you use on them... Want to keep them looking as close to OEM as possible..
    WOLF's Avatar
    I am WOLF.......
    Apr 2013
    Doncaster
    657
    Quote Originally Posted by dolcevita4 View Post
    Thisis pretty much it but its all in the prep.
    Mar 2009
    38
    I did a couple of sets on my old Civic Type R and my sister. Light kurbing and corrosion on them all. I have to say, after buying all the stuff, hours and hours of sanding to get them nice and flat, hours spraying them letting layers dry and trying to make sure no contaminates got in the lacquer I swore the £200-300 quid to have them done professionally was a bargain!!
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Quote Originally Posted by matts1 View Post
    Ah f**k really? I am just about to refurb mine. Surely if you use a 'mouse'/handheld sander it would be easier? I know with CTR wheels the spokes must be a bugger but on Audi fat 5s it must be a little bit easier with the size of the spokes? I hate paying people to do something I can do...hate it..
    2000 Audi A3 1.8T Sport AUM K03S|Second owner|Forge 007p|CM TIP|Yellow Dogbone|Pipercross panel
    To Fit - Decat then Mapping WANTED: Audi A4 B7 or MK5 Golf GTi (manual)(Want to Buy December 2014 so Keep Me in Mind)
    Oct 2012
    71
    I've just refurbed some S3 Ronal alloys for my A3 and it wasn't too bad - the sanding (by hand) takes a while - took me about an hour per wheel then spraying's ok - worth taking time over it. This is one of mine after spraying - if you're willing to put the time in then deffo worth doing it yourself as all the kit is sub £50 for doing all the wheels. ImageUploadedByTapatalk1390177881.183489.jpg
    Tuddie likes this.
    Oct 2012
    71
    Oct 2012
    71
    I used E-Tech metallic silver paint from EBay - looks pretty close to OEM.
    Nov 2013
    Heath Hayes
    951
    I was going to do this with the 17 inch winter wheels I bought off E-bay. They came cheap because they were quite rough.
    After looking around and working out how much I would have to spend on paint and materials as well as time ended up taking them to get them done Professionally.
    Went to the prestige wheel centre in Birmingham. For cash they will do wheels for the price with no VAT. So 4 wheels fully stripped , kerbing damage repaired and they have been sprayed all over with powder coat and look like new. All for £140 .
    Wheel refurbishing price guide for diamond cutting and powder coating
    You don't get the same satisfaction of doing the job yourself but there is no way I would have been able to do the wheels this good.
    Karl.
    A4_MaJiK likes this.
    Karls 312bhp A4 3.0 TDI build thread http://www.audi-sport.net/vb/audi-s4...ld-thread.html
    Mar 2009
    38
    If you enjoy that sort of task then it is worth a go, but for me, although I liked the results, it took me a good two days to do the four wheels and just seemed more hassle than coughing up for a professional job, the ctr wheels were a bugger
    before
    after
    a top tip, tape the edge of the tyre up between the rim and the tyre with masking tape, then use cling film to wrap the tyre - going around the radious of the tyre and tape the edge of the cling film to the tape round the rim, then use a hair dry to shrink the cling film to the tyre. Creates a snug cover for the tyre that wont tear of shift like paper.
    JudderMan likes this.
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    That looks spot on. I'm not afraid of a bit of hard work. I'd rather give it a whirl. Just need the time to do it really. Was thinking of sanding and prep on a Friday afternoon/evening, painting all wheels Saturday morning, left to cure, finish on Sunday, new wheels for Monday....just not this weekend...LOL.
    Mar 2009
    38
    If you can, get all four wheels off or a couple at a time. Yep, get them sanded down and clean and then maybe get a couple of coats of primer on and leave to harden over night - now I found out of a can it takes more like a few days to a week for them to really harden so you could do all four and then leave them on the car for a week to harden.
    Then you can wet sand them to get them flat and take out any imperfections - anything you can see now will be x10 when painted. Then give them a few coats of silver and a couple of lacquer 30 minutes later. I worked on all four in one go, so as I coated one, I did the next and the next then it was time to do the first again and so on so I wasn't waiting around watching paint dry too much!!
    Wants to be warm and free from dust or breeze/wind so ideally in a a garage but make sure you wear a mask and have some ventilation : ) and if some dust or fluff lands in the wet paint - leave it and sort it when it is dry unless you have a very very steady hand!
    JudderMan's Avatar
    Nov 2012
    Newcastle Upon Tyne
    744
    Thanks Matts1, taken onboard.
  1. Swap Alloy Wheels! My Audi 18s in Black for your 18s in Silver/grey! anyone..?
    By caraudiaye3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2013, 19:07
  2. Has anyone attempted to restore there own wheels?
    By RobMorris in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd November 2011, 16:10
  3. Telling your insurance company about your alloy wheel change.
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2010, 10:32
  4. How to refurb your own alloys
    By JimC64 in forum General Technical / How To
    Last Post: 6th October 2009, 15:51
  5. Alloy wheel cleaner & Brake callipers
    By Banwell in forum Detailing
    Last Post: 28th May 2003, 10:24
