Badger5EM Tuning
Results 1 to 12 of 12
    Mindak's Avatar
    Nov 2013
    Wiltshire
    244
    Karcher off water butt!
    Hi guys, does anybody here run their pressure washer off their water butt?
    bought myself a karcher k2 last week as hear they are compatible!
    A3 2.0 TDI S-Line
    AUDI_ADDICT's Avatar
    Nov 2012
    Hertfordshire
    60
    My brother runs his pressure washer off a water butt, but uses a pump that he got from Wickes to filter the water (and add some pressure as I don't think the pressure washer can drag the water through a hose alone). Seems to work fine..
    His pressure washer is old so not sure if the newer ones are different
    _Conrad_'s Avatar
    STRONIC
    Dec 2013
    Surrey
    53
    I think I've read somewhere it's not great for the paintwork to use rain water as it's more abrasive than filtered tap water but I'm sure you could filter it. Plus I'm not a professional detailer so could be wrong.
    Feb 2013
    124
    I run my Nilfisk from my water butt you need more than one butt, I use three first one is the filter.
    Mindak's Avatar
    Nov 2013
    Wiltshire
    244
    I'm not planning to use it up close, probs use if just for snow foam, washing off, under arches etc, do want to find out about filters though!
    A3 2.0 TDI S-Line
    Nov 2013
    72
    I have used the water from my water butt in a large water container. I used a small length of hose connected to my karcher without any issues. I think the karcher has a mesh filter where the lance attaches to the karcher.
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    i have the karcher k5 and use a water but with the karcher sucktion hose as it has i anty sython on it so all you do is put the filter end in the water but lift up and down a few times then connect it to your karcher and it works fine
    Mindak's Avatar
    Nov 2013
    Wiltshire
    244
    May have to look up about the suction hose, going to do a trial run on the patio first! Lol
    A3 2.0 TDI S-Line
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    i got the suction hose the only truble is that its not that long so i went to a garden center and got 10m of 22mm hose so i dont have to move the water butt that cost £10 cheaper then ebay
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,082
    The suction hose does seem very short, you can see it in this video. I just attach the hosepipe to the water butt tap (also in the video). I've found you can run a pretty long length of hose this way and it still works fine.
    Ch3tan's Avatar
    Nov 2013
    London
    43
    I use my nilfisk from a bucket of water with a small hose just fine. You don't need the suction kit.
    2011 A3 140 2.0TDI Black Edition
    madmanrsvr's Avatar
    Dec 2013
    devon
    81
    the truble with karcher is that if it has to suck from an empty hose it cuts off so you need to get the water down the hose and that is a good thing with no return valve
  1. Front off for Cam Belt and water pump
    By AshA4 in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 29th November 2013, 18:48
  2. Karcher Water Butt Cleaning
    By palfy86 in forum Detailing
    Last Post: 30th July 2013, 17:13
  3. blanking off rear wiper need to stop "water"r from working
    By sykotikman in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2013, 22:28
  4. Water pump running on after ignition off & draining battery - help please
    By The Doctor in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2011, 08:00
  5. Replies: 3
    Last Post: 3rd March 2008, 15:58
