Chris NottEM Tuning
    Nov 2013
    72
    Started to detail my new A4 2.0 avant Quattro
    So I managed to take a day off work and made a start on detailing my new Audi. Picked the car up on Tuesday and looked relatively clean.
    Quick jetwash then snowfoamed:
    Rinsed then washed with two bucket method.
    Then used Iron X to remove fallout. Car looked pretty clean after wash but as you can see quite alot of fallout!
    Then did the wheels, again as you can see alot of fallout, mind you to be expected on the wheels!
    Car has a few scratches, but nothing major, typical example of what I have to correct:
    Started correction using Menzerna PF2500 with yellow pad.
    Unfortunately time and weather were against me so I had to stop for the day.
    Off to London for the weekend but off work on Monday so will continue, hopefully my Werkstatt polishing kit recommended for white paint should arrive so I can complete the job.
    Updates to follow.
    Nov 2013
    Nice.. I bet white is a pain in the a$$ to keep clean!!
    JimmyH's Avatar
    Oct 2013
    Marham
    242
    Good luck dude, it'll look awesome once done.
    Nov 2013
    72
    Forgot to mention I clayed the car before I started scratch removal.
    Updates hopefully on Monday.
  1. New tyres for A6 Avant 2.5TDi sport quattro
    By fjtwelve in forum Handling
    Last Post: 4th October 2011, 19:44
  2. Just started doing detailing part-time in the SE area
    By LukeTripod87 in forum Detailing
    Last Post: 4th June 2011, 08:42
  3. New A6 3.0L (non quattro)
    By Defratos in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th July 2005, 14:58
  4. n00b questions from new a3 1.8 T quattro buyer
    By DrWu in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2003, 07:30
