Started to detail my new A4 2.0 avant Quattro
ianv5
NULL
So I managed to take a day off work and made a start on detailing my new Audi. Picked the car up on Tuesday and looked relatively clean.
Quick jetwash then snowfoamed:
Rinsed then washed with two bucket method.
Then used Iron X to remove fallout. Car looked pretty clean after wash but as you can see quite alot of fallout!
Then did the wheels, again as you can see alot of fallout, mind you to be expected on the wheels!
Car has a few scratches, but nothing major, typical example of what I have to correct:
Started correction using Menzerna PF2500 with yellow pad.
Unfortunately time and weather were against me so I had to stop for the day.
Off to London for the weekend but off work on Monday so will continue, hopefully my Werkstatt polishing kit recommended for white paint should arrive so I can complete the job.
Updates to follow.
Nice.. I bet white is a pain in the a$$ to keep clean!!
Good luck dude, it'll look awesome once done.
Forgot to mention I clayed the car before I started scratch removal.
Updates hopefully on Monday.
