Don't think I'd use snowfoam tbh, far better and more effective engine cleaners on the market and you're going to have to blast every wee bit with the pressure washer just to get rid of it, not a good idea to me.
Obviously yes but to a much lesser extent, a rinse with a hose will remove it easily. Proper snow foam on the other hand is much harder to break down and disperse and more importantly it's a much less effective cleaner.
I think it would be a waste of product just get some G101 a brush and some old MF's and give it a clean give the underside of the bonnet a blast with the PW
Snow foam is pretty poor in removing grime from paintwork let alone anything oily from an engine bay.I must admit i feel snow foam is a bit of a con in its claims.Only use is for loosening mud etc to a degree.Ive come to this conclusion by having tried several sf brands.
