Not new to machine polishing. Now at the w/e i machined our a6, its that dark green, met, and clayed first. Now i use 3m products and have done for some time, on our XJ, sliver, and our last car, (black) with no problems; but i ended up with holis on the side panels, not the bonnet or tail gate, or bumpers. Temp was not on the high side, not in direct sun either.
The hols are not bad, to most the hols would not be noticeable, to me yes they are. Is there any way around this, i could go over them again, with a panel wipe and then reapply top coat, or do i need to clay them back, or just use the machine again.
I have a M/g final polish, to use before final wax or top coat of your choice, could this be used to cut the hols, or use M/g final and panel wipe then apply last top coat.
Sounds complicated what i have wrote but you d/t out there know.
Kind regards Graham
Kind regards Graham
