Thread: Bad Haze
    Aug 2013
    Norfolk
    67
    Bad Haze
    I have recently bought a 2000 A3 Tdi 1.9 in cactus green, on the bonnet is some big patches of hazey paint that feels a little rough to the touch. Is it possible to buff this out and return the original shine to the paint work?
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    734
    Quote Originally Posted by joe_echo View Post
    Probably, but without seeing how can we tell lol.
    Post up some pics
    I'd read the stickies in this section as it will tell u all u need to know about decontaminating and buffing m8
    Audi A4 BE 2.0 TDI 177 Quattro
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,141
    Visit Craig Cull's Youtube Channel
    could be a few flatting marks from a previous paint job or just some form of contamination. I would give it a machine polish with either 3m fast cut or farrecla g3 or g6 rapid cut. After removing any compound left behind with a microfibre cloth I would use 3m fine compound or hologram remover with a soft pad on the machine polisher or 3m finesse. This should bring back the shine and remove any swirls. If your happy with the finish, remove ny excess with a microfibre and give it nice coat of wax
    if you need to know anything more pm me, I'll be happy to help.
    Aug 2013
    Norfolk
    67
    here is the haze I have. its abit difficult to see in the 2nd picture but in the first you can clearly see the white patches on the paint work
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,141
    Yeah I can see it. First I'd try using a clay bar and washing up liquid. Usually removes most contaminants. Failing that I would give it a wet flat with 2000 wet + dry then polish it up using the above process. If that doesn't remove it then it could be underneath or it could be solvent popping. This usually occurs when the painter applys too much lacquer with out leaving a reasonable flash off period between coats, then switches the oven to bake mode without letting the solvent evaporate, which forms a skin, then the solvent breaks through leaving little bubbles in the paint. The only way round this is to repaint I'm afraid. Its worth a shot tho.... :/
    K04 hybrid turbo. S3 injectors, Autotech hpfp internals, RS4 fuel pressure regulator, custom FMIC, APR carbonio intake, decat pipe, milltek cat back non resonated 100mm tips, unicorn developments custom remap, launch control and flat shift. Valet mode, economy map and full power map options. Stage 3 southbend clutch with single mass flywheel, Eibach pro street coilovers, eibach front and rear anti roll bars, porsche cayenne 6 pot calipers front, S4 rear brake conversion.
  1. Bad, bad day. My S3 got hurt
    By silvers3uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th December 2003, 07:42
  2. Audi Dealer good or bad?
    By colinreid in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2003, 13:14
  3. warning bad taste s3....
    By rockstar in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2003, 18:20
  4. chipping a 1.8t bad for engine?
    By twally in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th August 2003, 03:58
  5. Bad and the good
    By will_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2003, 18:50
