Volks AutosEM Tuning
Like Tree1Likes
  • 1 Post By RobbieWebs
Thread: Best way of disc between brake disc and alloy
    theo289's Avatar
    Oct 2012
    Bristol
    172
    Hi All,
    Probably one of the most vague posts here but i have a little bit of surface rust which i wish to remove between the brake disc and the alloy wheel. i've tried Iron Out and its removed a little bit of it but i'm looking for that little more va va voom with removing the surface rust - WD40? Brake cleaner? Surface cleaner? Cilit Bang?! (obviously wouldn't put cilit bang on them)
    Appriciate the help
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    683
    Quote Originally Posted by theo289 View Post
    Hi All,
    Appriciate the help
    Vague isn't the word lol.
    Take a pic and post it m8
    Is it around the brake disc on the outside ur on about?
    Or the wheel?
    Iron out is for metal filings and contaminates, not for derusting
    Audi A3 2010 2.0 TDI 140 Black Edition
    theo289's Avatar
    Oct 2012
    Bristol
    172
    Quote Originally Posted by RobbieWebs View Post
    Or the wheel?
    i did try my best! it is the little drum between the brake disc and the inisde of the alloy wheel - usually they get quite bad surface rust.
    will get a picture and upload it
    theo289's Avatar
    Oct 2012
    Bristol
    172
    After cleaning the same as what this guy here is spraying
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    683
    I might be wrong but I'm sure u can rub it down with sandpaper/ wire brush and paint it.
    I'd be carefull and mask off threads etc before doing it tho
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    683
    Rusty rear wheel hubs
    It seems every hub goes rusty m8, even the top spec
    fanta likes this.
  1. Gap between Rear brake pad and disc
    By DaveA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th March 2011, 11:51
  2. TDI quattro brakes - disc and pad upgrade
    By TDI_Boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th July 2006, 21:50
  3. S4 Brake Pads and Disc replaced
    By EnzoS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th March 2006, 23:36
  4. Where to buy rear brake discs and pads?
    By LeeW in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th April 2005, 20:10
  5. Brake Discs and pads S4 B5 2000
    By abmunro in forum Tuning
    Last Post: 24th March 2005, 04:32
