Results 1 to 11 of 11
Thread: Clean Air Con
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,683
    Clean Air Con
    My wife was complaining on Friday that the inside of the car smelled like cat pee, so I figured it was time to disinfect the air con.
    Popped into Halfords on Saturday & picked up one of those Comma anti-bacterial cleaners. I've used it before & it's very effective. All you do is move the front passenger seat fully forward, & place the canister on the rear footwell. Next, start the engine, switch the air con to recirculate, and put the fan on full speed. Finally, hit the button on the canister, lock it open so the aerosol spray is fixed on, & close the door. Ten minutes later, the canister is empty, all the cleaning stuff has been sucked right through into the system. Job done!
    While I was at Halfords, I noticed they sell replacement cabin pollen filters now, so I bought one, as the filter hasn't been changed at least as long as I've owned the car (2 & a half years), & probably a lot longer.
    It took old Captain Sausage-Fingers here a few minutes to undo all the clips & covers, but when I eventually found the old filter & pulled it out, it was minging! No way will I leave that job so long again!
    It smells very sweet inside the car now. The Comma cleaner is an excellent product, but you do need to give the interior surfaces a good wipe-round afterwards.
    [img]/ubbthreads/images/graemlins/ok.gif[/img]
    1.8TCraig's Avatar
    Jul 2006
    Glasgow
    11
    Just gave the Comma product a go dude on the strength of your reccomendation and I have to agree with you - it's a very good product and well worth the ten quid or so it costs
    1998 Audi A3 1.8T Sport - Kingfisher Blue
    tracer's Avatar
    '96 a4 1.8 se
    Oct 2005
    scotland
    266
    sounds good, will give it a try
    Aldo's Avatar
    Jun 2006
    1,004
    Please can some 1 tell me where the cabin pollen filters are?!
    I have a 03 B6 A4
    Aug 2004
    An der sud Koste
    711
    How much mess does it leave and what sort of mess?
    Does it end up all over the dash pod?
    Sportback
    May 2006
    Zummerset...Cider land.
    23
    I think i will be paying a visit to halfords tomorrow to give this a try, cheers.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,683
    Clean Air Con
    Quote Originally Posted by Aldo
    I have a 03 B6 A4
    Easy. Open up the bonnet. At the back, behind the main engine bulkhead. to the right of the battery. Remove the rubber beading from the front bulkhead, unclip the full width cover, then tease out the plastic cover to the right of the battery (you'll need to unclip a tube that runs across it). The pollen filter is underneath.
    Remove, replace, re-fit, job done. Takes 10 minutes.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,683
    Quote Originally Posted by cdb2
    Just a fine mist. Wipe it over with a clean cloth & you're fine.
    Aldo's Avatar
    Jun 2006
    1,004
    Quote Originally Posted by jdp1962
    Will take a look tonight or tomorrow, I saw you cleaned yours in washing up liquid, but did you then buy a new one, just wondering if I should just go out and buy a new one or not?!
    bainsyboy
    I use it every year and does make a difference, leaves a slight mist on speedo etc but wipes off easily enough.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,683
    I didn't buy a new one, cos the washing powder did a good cleaning job (even if the thing smelled of Daz for a week afterwards). Dealer put a new one in last week, though, as part of service.
