Monster MotorsportBadger5
Results 1 to 7 of 7
    Apr 2004
    Oldham
    Blower on heater A4 playing up.
    The blower for the climate control on my 2001 (new shape) A4 takes about 10 minutes to start spinning on these cold mornings. It's being demanded on at full speed. Is this a common problem ? and where is the fan on the car please ?
    Thanks, [img]/ubbthreads/images/graemlins/confused.gif[/img]
    easytease's Avatar
    cheesypeas
    Nov 2005
    england, surrey
    426
    Re: Blower on heater A4 playing up.
    could it be frozen at all?
    Nov 2005
    UK
    586
    Not 100% certain, but I think you will find that with Climate Control, it will only work at full speed once it can pump warm air into the cabin. It therefore must wait until the engine is warm before circulating air with any speed.
    If I press the front windscreen demisting button , I think it must override this and the fan comes on full blast, so just an idea but maybe worth a try.
    hop2407's Avatar
    Oct 2004
    Derbyshire
    1,408
    [ QUOTE ]
    [/ QUOTE ]
    I have an older model A4 ('97) so can only comment on that but would imagine the CC setup are not far apart from the 2......
    Shadowman is indeed correct..... when heat is required, the blower graduates in terms of blowing the hot / warm air out....... On Mine there is a '+' and '-' to override this however if it is pressed immediately on startup, cold air will be delivered until its had time to warm up.....
    And as for the windscreen setting - same applies - press this and it overrides the blower gradual increase and pumps out the air at almost full speed......
    Lastly, my blower / pump (not a fan) is situated behind the glove box - there are many threads on AS.net about this as a few of us have had to replace the blower....
    If my A4 and yours ARE completely different setup - then I guess ignore the above eh !! [img]/ubbthreads/images/graemlins/beerchug.gif[/img]
    hop2407's Avatar
    Oct 2004
    Derbyshire
    1,408
    One more thing that a few may notice over the winter months...... The snowflake or Air Con sign may dissappear...... this is quite normal....(Well on the older models with CC anyway)
    The system basically shuts itself off to protect itself and will only come back on when the outside temp is at about 3 or 4 degrees......
    There will be NO impact on the hot and cold air deliver or widscreen demist - Just not get full aircon.........
    Even pressing the 'snowflake / aircon' button (if you have one) will not engage it
    audi5e's Avatar
    Jun 2004
    Johannesburg, South Africa
    809
    I think you can get the aircon compressor to switch on in very cold temps if you press the demist button??? (it hardly ever gets cold enough here to see... :-)) )
    Apr 2004
    Oldham
    Thanks all, but its definately a faulty blower. It's intermittant and sometimes it's ok, other times it doesn't spin. Seems like a classic case of blower itus, but I'm having trouble identifying which one to buy. Mine is a 2001 A4 1.8T quattro, but it's the newer shape. The Chassis begins with 8EZ1 and none of the usual web sites list that.. HELP !
