Chris NottEM Tuning
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Nattys Blue with DA?
    After a lot of reading on various detailing forums (and on here of course) I've just placed an order for some Poor Boys Black Hole and some Natty's Blue Paste wax to treat my Panther Black.
    My brother works as a sprayer/refinisher for Aston's so he's going to borrow a rotary polisher from his work to compound the car first, to hopefully get rid of some of the imperfections.
    He's leant me his own Rupes DA and I've ordered some new Menzerna supersoft finishing pads for it so I can use it for the glaze/wax stages. (I'll admit I'm no expert so I didn't fancy using the rotary, which is why he's doing that bit and I'm sticking to the relatively safer DA part).
    From what I've read, the PB Black Hole works very well when applied by DA, but is the same to be said for the Natty's Blue?
    The DA doesn't have a variable speed, it's just set at 7000rpm. I know if it was a rotary polisher then it would be too fast, but will the way the DA works mean it's ok?
    Now: 2010 A3 SB S-Line Black Edition 2.0TDi 140CR. Panther Black
    Retro'd: Black S-Line badges | Private Plate | Come home lights activated | Fogs as corning lights activated | Hill hold assist activated | TPMS (via VCDS) activated | 3.5" s/s tailpipe | LED interior lighting.
    Gone: 2007 A3 SB Sport TDI 140. Dolphin Grey
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    405
    If you're worried, try a test spot with the lightest pad you can find and work quicker than you'd expect.
    Then slow the speed or up the pad density until you reach the required setup.
    I would never apply a wax by DA personnaly. Too easy to apply too much and not get a true feel of how its being applied.
    A sealant by all means apply with a DA and black pad. Generally its machine for liquid, hand for solid.p
    EDIT: Also is that Aston Vauxhall? I live a couple villages away and alway pass by. Bought my previous Corsa vxr from them and good friends with all the sales people.
    danb986's Avatar
    In awe of VCDS
    Apr 2011
    Hertfordshire
    505
    Quote Originally Posted by coreythorny View Post
    No, I mean Aston Martin. The Heritage centre in Bovingdon.
    Cheers for the advice. I guess I'll stick to applying wax by hand then. I was hoping to save myself a bit of elbow grease and use the DA for applying everything. When you say it's too easy to apply too much, wouldn't the DA 'spread' it around so you end up with an even coat? Or is the wax too solid for it to work like that?
    Feb 2011
    Falkirk
    296
    I use a rotory on my car for the polishes but always put the wax on by hand. I am by far an expert and only bought the rotory as it was on sale
    russwuss's Avatar
    Feb 2013
    368
    Apply natty boys with a microfibres applicator.. Although it's not a hard wax I wouldn't recommend rubbing it onto a polishing pad then working it into the car. I have a pot of Natty Boys, very good wax, beads for a long time - easy to apply, leave for ten - fifteen minutes then take off with a microfibre cloth.
    Also have a bottle of Black Hole, used on a black MK4 Golf and now my S3 is wearing it :-) very good results on both cars.. I'm sure you'll be impressed.
    next up to try on the S3 is Prima Amigo with Dodo Juice Supernatural Wax :D
  1. Pics of Sprint Blue with Optics
    By Boydie in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th July 2009, 13:11
  2. Looking for pics of S3 sprint Blue with Black styling package
    By gr1zly in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2008, 21:28
