Badger5Sky Insurance
Results 1 to 11 of 11
Like Tree2Likes
  • 1 Post By WOLF
  • 1 Post By Brodster
Thread: Question re: tar spots / swirls
    May 2013
    11
    Afternoon all, I'm knew to the world of detailing (in fact I've never cleaned a car before now - lazy!) but last week gave our new A3 some much needed TLC. Our car is black and had a lot of swirls from the previous owner which were extremely noticeable particuarly when the sun shone on it. After a good going over with Poorboys Black Hole Glaze its looking alot better but upon close inspection I can still see visible marks. Question to the group, is it a case of giving the car anther wash and repeat with the Poorboy's to remove these further or do I need to take more drastic action?
    Secondly, when I was cleaning the front I noticed alot of tar spots so a quick read around and some Tardis has been ordered. Question, is there anywhere on the front section that I should avoid getting this stuff on?
    So far I've been impressed with what can be done with a little bit of elbow grease but can't wait to get the remaining crud off the car.
    T3nnant's Avatar
    Jan 2013
    Newcastle
    362
    Congrats and welcome to detailing haha.
    As for the swirls... you wont be removing them as suck with blackhole.
    you will need some cutting compound to remove a very thin layer of clear to remove them. Using a DA polisher will work best but read up on it first.
    to remove the bits of tar I bought AUTOGYLM tar remover. works a treat but will leave a small amount of scratches so need to use cutting compound
    WOLF's Avatar
    I am WOLF.......
    Apr 2013
    Doncaster
    638
    For tar spots i use good old WD-40,works a treat.
    AUDI_ADDICT likes this.
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,393
    Follow Brodster On Twitter Add Brodster on Facebook
    Yep WD-40 here too. Obviously sprayed on after the car has been washed so no grit is wiped across the paint. I very rarely use clay bar anymore because if the car is loaded with tar you have a massive chance of scratching the paint with the remnants of tar held on the clay bar. Leave the WD-40 on for afew minutes then carefully wipe off then wash the car again to remove residue. Voila
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    May 2013
    11
    So how does the WD-40 work? Melting the tar? Interesting, never thought of using that so will give it a try. Anyone else used Autosmart Tardis?
    Jan 2012
    SW London
    794
    Could use a clay bar for tar spots too, if ur willing to spend the time to clay the front end. does take a while to do properly, and will take even longer if its never been done before. In fact that would be better prior to using ur black hole stuff.
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,393
    WD-40 contains petroleum which breaks the tar down and kind of melts it so that you can just gently wipe it away. If your going to use this method ensure you wash the car again to get rid of all residue from the paintwork. I know alot of detailers use WD-40 as its safe, quick and easy to use.
    May 2013
    11
    Interesting, thanks chaps. Sounds like the tar spots are easy to remove so that's good. Some fun to be had at the weekend then.
    Assume once I've removed the tar it's worth giving the whole front end a polish and re-wax? Not sure I can be bothered to do the whole car again so soon so could I get away with a quick Detailer for the rest?
    Brodster's Avatar
    Mar 2011
    Scottish Borders
    3,393
    Once you remove the tar make sure you wash it again and then quick detailer if you want.
    markwiggy's Avatar
    Third Gear
    Oct 2006
    North West
    1,123
    Quote Originally Posted by ~dadam02~ View Post
    I always use Tardis, brilliant stuff, removes all tar and other contaminants that have bonded to the paint, reducing the need for claying. I do a panel at a time, spray on, leave for a minute or two and then wipe it over with a cloth, rinse panel with cold water. I then rewash the car after. Never used WD40 so can't comment on that one.
    Mark
    07 S3 Sprint Blue Now Sold
    12 Range Rover Evoque Dynamic Now sold
    A3 20 TDI S-Line Sportback in Daytona Grey with Aluminium Roof Rails, Fine Nappa Leather, Sat Nav, Comfort pack,Audi Sound System, Folding Mirrors, Heated Seats, Privacy Glass, Interior Light Pack, Non Smoke Pack.
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    418
    I used Tardis or ObliTARate. Both very good at it. Occasionally ill use Trix which also removes iron contaminants which more obvious on light cars.
    Never tried WD40 but have heard it works. Saves buying a specific product I guess!
  1. Tar spots (Alloys)
    By James.Asbri in forum Detailing
    Last Post: 23rd December 2009, 11:25
  2. Stubborn Brake Dust... and tar spots
    By Juniper44 in forum Detailing
    Last Post: 4th September 2009, 22:13
  3. black (tar) spots - autoglym or quick clay
    By tj1978 in forum Detailing
    Last Post: 15th April 2007, 21:36
  4. Advice Needed On Removing Tar Spots
    By Fluff in forum Detailing
    Last Post: 29th April 2004, 09:54
  5. Couple of questions for admin...
    By MickHumphrey in forum General Chat
    Last Post: 2nd January 2003, 17:04
