Badger5Sky Insurance
Results 1 to 15 of 15
    May 2013
    Co Durham
    72
    Add Fenriz on Facebook
    Looking for pressure washer lance
    Hi guys
    I hope someone can help me out here, I have a fairly old Power Devil pressure washer which has the following hose conections
    I have just brought the following snow foam lance with this connector
    Unforunatley it doesn't fit my current lance, could someone please point me in the direction of one that would be suitable.
    Thanks in advance for any help.
    Brilliant Red A3 2.0 TDI S-Line Quattro 140 | S3 Black Optics Grille | 18" Black Edition Alloys
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,402
    Follow Brodster On Twitter Add Brodster on Facebook
    When I bought my foam lance I had to specify which pressure washer it was connecting to so that the right adaptor could be supplied.........have a look on Car Care Products | Detailing Products | UK - Clean Your Car to see if they do just the adaptors.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    coreythorny's Avatar
    Mar 2013
    Leicestershire
    425
    You don't want the hose connection, you need the connection on the lance itself!
    On my Nilfisk i have the trigger/gun then a lance them nozzle.
    The snow foam lance goes straight into the gun so if you get a picture of each fitting, end of gun and lance I can help tell you which you need.
    I actually have a spare Karcher adapter which came spare with my lance if its that size you can have it free.
    May 2013
    Co Durham
    72
    Thanks for replying guys, here are some close ups. The first one is the thread that screws the standard lance onto the trigger, the second is the thread that is on the snow foam lance.
    I hope this is helpful and makes sense to you.
    Mar 2013
    Leicestershire
    425
    That's a unique fitting, is it the only fitting available after the trigger unit? Here's the fittings available for a snow foam lance:
    May 2013
    Co Durham
    72
    Yes that is the only fitting, I thought it was an unusual fitting. What I'd be looking for then is a new trigger and lance assembly that would allow my snow foam lance to attach to.
    Could you recommend a new trigger/lance that would be suitable for my snow foam lance then?
    Mar 2013
    Leicestershire
    425
    I don't know if it would be that easy?
    on my Nilfsik the fitting out the pressure washer itself is a standard thread, not sure off the too of my head but its approx a 3/4" BSP fitting.
    Is yours the same?
    if so you might actually be able to buy a Nilfisk hose etc and fit it to your unit? Not sure.
    May 2013
    Co Durham
    72
    Just looked on ebay and this looks like it might do the trick, the end section that screws into the trigger assembly looks to have the same thread as my snow foam lance. What do you think.
    Pressure Washer Hose,Trigger gun and lance set * Choice of Hose Lengths* | eBay
    Mar 2013
    Leicestershire
    425
    Yeah your snow foam lance looks a M22 fitting so should fit onto the gun of that one.
    Jut make sure you can connect the actually hose to the pressure washer unit! Or your hose onto that gun? If that makes sense.
    May 2013
    Co Durham
    72
    Yeah makes sense, looks like it has the standard screw on attachment to the washer unit.
    Thanks for all your input Coreythorny
    Mar 2013
    Leicestershire
    425
    No worries mate, hope I've been of some help!
    Put some foamy pictures up also, try and get this detailing section moving more
    May 2013
    Co Durham
    72
    Well finally got a snow foam lance, had to buy a new trigger assembly though. So here's a couple of pics, need to find the right mixture setting but at least she got her first foaming.
    Mar 2013
    Leicestershire
    425
    Nice to see mate!
    What foam you got?
    the general rule is, with a 1l bottle, 1" of foam, rest warm water. Give a little shake.
    Close the top valve (PA), then back off half a turn.
    Then turn the nozzle to suit your required spray pattern, I normally have it spraying 1ft wide from 2ft away (at a guess lol)
    May 2013
    Co Durham
    72
    Thanks for the info Corey, I half filled ny 1L bottle up with foam lol
    I got this snow foam UAS Car Care Wild Cherry Snow Foam
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,077
    Also if you're feeling lazy I find you can pressure rinse the car first, then put your ordinary shampoo in the lance and foam it on. Then nip round with a mitt and a rinse bucket. Job done really quickly.
  1. Snow foam lance for a Stihl pressure washer
    By me77or in forum Detailing
    Last Post: 16th February 2014, 23:01
  2. Looking for an RS4
    By FatBoy in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th November 2010, 16:35
  3. Looking for foam lance attatchment
    By remslie20 in forum Detailing
    Last Post: 1st March 2010, 11:10
  4. Replies: 29
    Last Post: 10th December 2009, 10:28
  5. Turbo noise and type - looking for some help
    By Holywood in forum Diesel forum
    Last Post: 28th August 2003, 16:47
