JMB RetrofitsBadger5
Results 1 to 12 of 12
    SJW
    Apr 2013
    209
    Heavy Tar Deposit
    Good Morning All,
    Hopefully somebody with alot more knowledge in detailing than myself can help me out.
    Picked the wife up from work and she failed to tell me before hand that a large portion of the roads near her office had the top layer of road surface removed and amongst the loose stones were tar deposits which splashed the undercarriage of the car and the less obvious part of the side skirts.
    As the tar is relatively thick and not at the real sticky stage, more dry, would it be better to use Carpro Tar X??? I really do not want to agitate and let the treatment do most of the work. Is Tar X good for this job or is there another product I should consider??
    Quite annoyed as the car is a brand new A3 Sportback S-Line in White.
    Appreciate any help/guidance.
    Steve
    RobbieWebs's Avatar
    Apr 2013
    Scotland
    739
    From what iv read most use Tar x.
    Iv read autosmarts Tardis is better for heavier deposits of tar tho.
    http://www.polishedbliss.co.uk/acata...rdis-cat6.html
    U get smaller bottles than that
    Audi A4 BE 2.0 TDI 177 Quattro
    Mar 2013
    Near Oxford
    406
    Tardis is by far the best product I've found, I bought quite a few before going for this one, the others did nothing, Tardis took the tar away with ease.
    palfy86's Avatar
    Aug 2010
    Nottinghamshire
    238
    ive been looking at tardis, can someone tell me the best method to use this stuff please.
    scotty76's Avatar
    Nov 2011
    Berkshire
    1,084
    If you click the Polished Bliss link above there's a "How to Use" tab that explains all.
    palfy86's Avatar
    Aug 2010
    Nottinghamshire
    238
    Ahhh i see. cheers scotty.
    Jun 2011
    Great Melton Norfolk
    1,356
    If car has laquer coat use white spirit to dissolve the Tar
    Mar 2013
    Berkshire
    399
    You are better off with Tardis. Tar-X is over rated thou will get the job done but for the cost of it per use is a lot higher than of Tardis.
    And you can pretty much use tardis on anything so its very versitile.
    I put tardis in a spray bottle spray it on the affected area then just wipe off or just spray on then pressure wash it off.
    Brodster's Avatar
    Shark Performance In Scotland
    Mar 2011
    Scottish Borders
    3,403
    Follow Brodster On Twitter Add Brodster on Facebook
    Angelwax Revelation is very good and smells divine. As was said in a previous comment.....white spirit also but in small quantities.
    Angelwax/BBS/BCS/Bilstein/Cobra/CTS Turbo/DTUK/H&R/K-Sport/KW/Loba/Milltek/Shark Performance/Oz Racing/TPI/VCDS/V-Maxx/Vossen/Wagner
    SJW
    Apr 2013
    209
    Thanks RobbieWebs, MadMike & Giosabcsl. Looks like a unanimous on Tardis. Brodster, I have made a note on the AngelWax. Thanks.
    Ive bought a tester of Tar-X and ordered late yesterday some Tardis. I trust the Tardis only comes in a large quantity? Putting it into a spray bottle makes sense.
    I will try the Tar-X to treat one side and see how I get on with the Tardis on the other.
    Ive used White Spirits in the house and other places but do not feel comfortable applying to a new car Gen Heinze.
    Many thanks for all your replies.
    I will put my results up in here if others are interested.
    Thanks again,
    Steve
    Mar 2010
    154
    You can buy 500ml or 1l bottles fo Tardis on eBay, from valleters decanting from a larger drum
    Spray on the affected area, leave 5-10 minutes (you'll see the tar spots/splashes running) and wipe or wash off - you may need a second go if the tar is very dry or thick.
    Tardis will remove wax / sealant though so you'll have to reapply those afterwards
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,487
    Quote Originally Posted by SJW View Post
    Thanks again,
    Steve
    Yes Steve, put the results up, it may help others to make up there mind on the best products. x
  1. grip force heavy duty clutch kit
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th June 2004, 04:44
  2. Advice Needed On Removing Tar Spots
    By Fluff in forum Detailing
    Last Post: 29th April 2004, 09:54
  3. Is my TDI a little heavy on juice?
    By Irish in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2004, 13:56
  4. Put a deposit down....
    By excursion in forum General Chat
    Last Post: 7th July 2003, 18:21
  5. Heavy Spray.
    By Banwell in forum Detailing
    Last Post: 3rd July 2003, 22:45
