Chris NottMonster Motorsport
Like Tree5Likes
  • 3 Post By Amason007
  • 1 Post By ajax1976
  • 1 Post By Amason007
Thread: Best Cutting Compound for Audi Paint?
    Jan 2012
    1,599
    As above, I bought a MegsG220 along with 3M Fast Cut Plus, Ultrafina and Extra Fine Compound using Hex Logic pads.
    I set to work (the car has been clayed, de-ironed, tfr'd etc) this morning with the Orange cut pad and the Fast Cut Plus and though it did remove some light swirls it didn't remove them all which I'm a bit disappointed about (only done the bonnet) as my wrists are now broken!
    Maybe my technique is wrong, but if there anything out there suited to hard Audi paint?
    Thanks!
    Amason007's Avatar
    Nov 2011
    SE London/Kent
    117
    Hi Chris,
    I'm using the same combination. I no expert but managed to go from this
    to this on my bonnet recently.
    Are you giving the compound time to breakdown and do its work? I needed to use quite a lot of pressure and kept going until the compound has almost vanished, just a light haze remained.
    Although these are only swirl marks and not scratches. But if i had a scratch, i would work on that area for longer.
    Hope that helps?
    Andy
    scotty76, a6-chris and gupsterg like this.
    ajax1976's Avatar
    Oct 2012
    Fife, Scotland
    382
    As above polishes need to break down to work but only thing I would suggest is that it takes a long time with a DA polisher, rotaries are better suited to hard paints like Audi.
    Menzerna polishes are excellent on harder paints too though if you fancy giving that a try first.
    a6-chris likes this.
    Jan 2012
    1,599
    Thanks guys - used amasons advice and used a little bit more pressure, this seemed to improve things but to not as much as I would like.
    ajax - thanks for the advice, are the hex-logic pads fine? or will i change these too? im not wanting total correction but just the majority of swirls and holograms to be removed.
    Daytona Grey RS3
    May 2008
    Bracknell
    35
    Just did my M3 with Megs DA and microfibre system. Worked well tbh. I also did my X5 yesterday (albeit it only had light swirls) with All in One (AIO) Britemax. This was applied with the same microfibre polishing pads and the results were really good. I will be using AIO Britemax alot more from now on.
    Amason007's Avatar
    Nov 2011
    SE London/Kent
    117
    Quote Originally Posted by a6-chris View Post
    Chris,
    pop over to Machine Polishing - Detailing World
    Lots of info there.
    Andy
  1. Next Best Back Box For Audi a3 3.2
    By ksmiley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th June 2012, 13:30
  2. Best Tyre's for Audi A3 TDI 1.9
    By spaceman86 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th July 2011, 13:31
  3. Whats the best bike rack for Audi A4?
    By DJM1982 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th April 2010, 20:35
  4. Best phone for Audi factory kit
    By jonmusicman in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th April 2009, 13:05
  5. Best Oil for Audi TDI
    By slips in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2004, 09:31
