EM TuningMonster Motorsport
Results 1 to 7 of 7
    Nov 2004
    103
    Paint splatter on my paintwork
    Hi - painters at work painting the outside of the building managed to get tiny splatters of white paint all over my car. It was the wind apparently. Anyway, they offered to pay for the paintwork to be corrected. It was apparently water based paint, tiny dots but by the time I'd noticed was about a week later. A friend of mine machine polished the car which got rid of the majority of the paint dots but a few stubborn ones remain.... they are very hard - cant pick them off.
    so... any suggestions on what I could try on those stubborn ones ? I have been researching and read nail varnish remover, white spirit, thinners... as its water based I'm not sure if they are valid options. Any suggestions would be greatly appreciated, thanks.
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    2,001
    I had the same sort of thing and was advised by the knowledgeable ones on here to clay bar it, which I did and it worked fine.
    So try claying it, as recommended by ASN's detailing gurus, and me.
    JSD 2.59
    Synergy-Solutions
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,753
    i had a similar problem on my car that polish, and clay bars would not shift!
    i had white splashes of some very stubborn unknown paint that just would not budge!
    i fixed this by asking a few pro's on detailing world, and there answers worked for me!
    and was as follows!
    wash car first
    fill a small pot with PETROL, that is correct petrol and some cotton buds!
    fill another bucket of car shampoo.
    ok,
    after washing car and drying it, apply petrol with cotton bud direct to a spot of paint, gently dabbing and gradually dissolving it!
    have patience and do not scrub, but gently moisten the spot with petrol, over and over until as if by magic! it just lifts away! as the petrol will have dissolved its adhesion to the paint!
    when the spot has gone, rinse thoroughly with your shampoo to remove the petrol!
    repeat on all areas, but being very careful not to do this on plastic trim areas, then wash car fully!
    this WILL remove them!
    trust me!
    they were too big on my car, (about a pin head size) for a clay bar to remove safely, and this method worked for me! any larger than this and you can actually mar the paint by removing with a clay bar, as it rips it off the paint surface!
    ScottD3's Avatar
    Nov 2010
    English Riviera
    14,993
    Quote Originally Posted by sidibear View Post
    +1
    It worked a treat with me.
    The tougher bits came off with a bit more elbow grease.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    Furkz's Avatar
    Apr 2013
    298
    what about a Meguiars Glaze, i used to use this on my black paint when it got bad over winter and the paint got marked by the weather, really badly. when nothing else shifted it i used a Megs Glaze out of the professional range. BUT you will have to research the number yourself because i cant remember, sorry
    Phantom Audi A4 B7 S-Line Avant
    Feb 2013
    27
    I used wd40 to remove road tar!!!!! which was all the way along the outer cill worked a treat. then just simply give car a good premium wash. Don't forget try a small area first.
    Apr 2009
    Coventry
    2,219
    Ive used those dylon clothes stain removers before, theres one that does paint and tar.Get it from a supermarket, but dont get the dr beckman stuff cos its shhyte.Just dab it on and wash off.If you are trying any method try it on a small bit of a door shut just to make sure
    Pass me my sock
    Want to help cure cancer? http://folding.stanford.edu/English/HomePage
  1. Painting parts for cheap
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 15:31
  2. painted mouldings
    By ImportRacer in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th August 2003, 12:17
  3. Replies: 5
    Last Post: 31st July 2003, 08:46
  4. SILVER A3 PAINT CODE
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2003, 17:28
  5. Paint Restoration - post Scotland Meet
    By AL_B in forum Other Brands & Models
    Last Post: 24th March 2003, 21:00
