EM TuningBadger5
Thread: jetseal 109
    simon.m's Avatar
    Oct 2009
    2,746
    jetseal 109
    as above i have some jetseal i give the car 2 good coats around the 5th of dec it seemed good but i see its not beeding up now just a mth on i read it protect the car for up to 8mths so my ? is when i do the car again can i add a wax and then the jetseal to give it some really good protection. not to happy that its flat now its raining
    AUDI_ADDICT's Avatar
    Nov 2012
    Hertfordshire
    60
    I think the wax goes on top? I've just Jetsealed my car and it has made quite a difference, not amazing, but I did it because I wanted to protect the paintwork from these cold elements.
    I'm sure someone will be along soon to give you the correct procedure
    Oct 2012
    East Kilbride
    343
    if you are going to use both a wax and a sealant, then the wax goes on last....
    Mar 2008
    1,041
    jet seal first then leave it a good hour before putting wax on top ... if your using dodo juice wax give it one coat then leave it a day then apply the second coat then next day then the water will beed like a trooper for you
    simon.m's Avatar
    Oct 2009
    2,746
    thanks guys not sure what wax yet
  1. Blacklight Vs. Jetseal 109
    By KevinOS in forum Detailing
    Last Post: 6th February 2012, 21:29
  2. TIMING BELT TENSIONER DAMPER (06B 109 477)
    By AGU-TURBO in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th May 2011, 11:55
  3. CG Jetseal
    By axelfols in forum Detailing
    Last Post: 1st May 2008, 18:22
  4. 058 109 479 B damper cambelt
    By Bellic in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2007, 13:32
  5. Hydraulic Damper 06B 109 477 ?
    By bono in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2007, 17:13
